Part number please for a ..........
Started by tigers_gonads, 19 March 2022, 14:34:20
tigers_gonads
02 plate 3.2 Mv6 estate rear wheel bearing ?
TIA  :)
biggriffin
Hoof'land storeman.
Migv6 le Frog Fan
Part number please for a rear wheel bearing for a Calibra.  ;D ;D
Quote from: tigers_gonads on 19 March 2022, 14:34:20
TIA  :)
Are you really going to try and buy a wheel bearing from Vauxhall?
Your local motor factor will supply that for less hassle, and a good one will allow you to pick a brand like Timken or SKF if you don't fancy a gamble on a possibly cheaper one for £47.44  LINK  Those have gone up; when I bought them for my car they were about £25.
tigers_gonads
All ready bought a bearing but got a feeling I've been sent the wrong one.
Contacted the sender and he has requested the VX part number
Quote from: Nick W on 19 March 2022, 18:34:54
TIA  :)
Nige/Entwood fitted an aftermarket bearing to the front of his car, it lasted a very short time before it failed. He was in French France when it did & the garage he took it to would only replace both front bearings. I shelled out c£100 from Vauxhall at around the same time for mine & never had a further problem. Sometimes OE is best.
sjc
According to EPC: 90235281 superceded to 90486468 (which is a kit inc snap ring and locking plate)
Quote from: Andy B on 22 March 2022, 20:22:09
TIA  :)
Not quite the same thing though: a front bearing is built into the hub, and is a model specific part. The rear bearing is a standard double row bearing that could be used for many other industrial applications. Which makes it fairly easy to get them cheap, or from a reputable manufacturer if you don't feel like gambling another £25
johnnydog
TIA  :)
Although not relative to the subject of rear wheel bearings, I bought two new front hubs for the Omega - one was genuine GM, and the other a NOS AP Lockheed unit - both were fitted with Koyo bearings. I do try to stick with genuine GM, but this just reinforces that other makes of equally good bearings can often be bought for less money than GM boxed parts.
biggriffin
Hoof'land storeman.
tigers_gonads
Quote from: sjc on 23 March 2022, 15:12:24
