Diff Refurb/Removal
Started by grifter, 22 April 2022, 05:05:19
grifter
Hi All
When I was out last night I was sure I could hear the diff a bit more than I usually do, I do have selective hearing so it may be that (!). It's not at the stage yet that you always heard the car coming before you seen it, like the carltons were famous for.
The diff pinion is leaking and I was thinking rather than try and do that myself, a job I've never done, and I don't have proper ramps (to give me the leverage length for purchase to remove the pinion nut), I was thinking wouldn't it be easier to just drop the diff out and send it to a machine shop to get new bearings and seals, is it easy enough to remove or is it a subframe out jobby?
Imagine with the continual low oil level that the bearings are probably worth replacing anyway.
Cheers
G
You're unlikely to get the preload correct when you rebuild it, so it makes sense to get it done by a dedicated place.
A starting point would be to actually put some fluid in it.
biggriffin
Removing the diff is easy, pop drive shafts, remove abs sensors, unbolt from hanging plate, it's out. Hour including tea
The pinion seal, there's a guide, that DTM bloke did, the two seals were drive shafts go is a simple old out new in,
Hoof'land storeman.
Pinion seal I used to do on axle stands, not to hard but needs a deep socket.
I suspect its just low on oil so worth a top up, there was a bolt you could remove and drill out to create a drain, but its been a while and I can't recall which one it was..
omegod
The Diff weighs more that Vanessa Feltz so watch your self when dropping it out !!
GastronomicKleptomaniac
Its not too hard to remove as long as the car is high and secure so you can get a good breaker bar on the bolts if needed... Depends how well they're in!
grifter
Quote from: Doctor Gollum on 22 April 2022, 10:22:36
It's got a top up recently, had a fight getting the filler plug out had to grind down a allen key socket to fit. Yeah I'm not confident doing it myself, especially lying in my back underneath it, plus I've not got the torque to tighten it up again, think it was a high torque if I remember rightly.
grifter
Quote from: omegod on 22 April 2022, 13:43:54
Just drop it on my belly, be like a kid jumping on a trampoline!
Mutha Jugs n Speed
I've punted my cars around local companies who do rebuilds but... I got the sharp intake of breath treatment, and was told that they didn't want a car clogging up their workshop space whilst waiting for non existent spares. So pardon me for breathing, and I'll  jog on and keep my hard earned in my Swiss bank account ::)
biggriffin
Quote from: Mutha Jugs n Speed on 22 April 2022, 17:09:11
Yours are slippers, don't know if some bits still available,, would be worth a look in the Classic mags as there's lots of blokes in sheds that advertise in them.
Hoof'land storeman.
grifter
There's a big engineering shop in Glasgow that do anything and everything, I'm sure they'd be able to do change a seal and bearings in a diff.
Mutha Jugs n Speed
BG is right, two of my cars have limited slips, which may or may not complicate things a bit more. So looking further into the future and  Boris the bullshitters green plan for us all, then some extra sound deadening on the boot floor and under the rear seat area, and a pair of ear defenders......job's a good 'un and money saved ;)
Ive got my LSD in with q local firm. I don't think he's looked at it yet (the perils of being good is that he's busy all the time) but I woll report back with what he has been able to do  if anything.
biggriffin
Hoof'land storeman.
Outside of the box...
Carlton rear subframe and a Monaro diff...
Ought to be a few more places overhauling diffs for the Pontiac GTO*
*aka Monaro ;)
