Help! Error code P1700
Started by Migalot, 29 April 2022, 19:59:08
Migalot
Yabba-Dabba-Doo!
Thanks to the great Omega wizard, JamesV6CDX, the fault was located and the offending item (the main autobox solenoid) replaced.
Fault codes all gone! Smooth changes through the gears.
I am over the moon. Aside from his knowledge, his energy and his optimism, he's a real gent!  :)
So, today saw the solenoid fixed, yucky ATF replaced, fuel filter replaced, plus a full engine oil change. Coming back soon to do the brake discs and pads, cambelt, aux belt, plug change and oil pressure switch replacement.
Great weather and a great day!  :y :y :y :y
grifter
I haven't looked at the diagram yet as I'm posting from mobile and only a flying visit - but if it helps, it's the larger of the two solenoids, in the front sump, with the push on spade connectors :y
Migalot
Quote from: grifter on 17 May 2022, 20:51:06
out of interest, what valve was it? Looking at this diagram was it 17 or 18 or another one?
https://vauxhall.catalogs-parts.com/#{client:1;page:part;lang:en;category:car;catalog:v94;group:h;groupsub:2;subgroup:8-0}#18
Looking at the invoice from JPAT, the description is:
Part No: N147 35 09 Solenoid, EPC, 4L60E 93-02, 4L80E 94-03, OEM
Quote from: Migalot on 17 May 2022, 21:31:49
Interesting - I'm sure this box is a 4L30-E (and IIRC, the additional front part / sump was an upgrade from an earlier GM box).
But let's not concern ourselves too much - it works now! :y
Electrically speaking the 4LxxE is ostensibly the same box.
The 4 is the number of forward gears,
L is the layout
xx is the torque rating
E is the electronic control instead of mechanical.  :y
Raeturbo
Well done James, you're a Demigod👍 My Mv6 is still pulling like a good honest man pulling something off his granny👍👍👍😂
Laying a rubber road.
Well done, James, again  :-*
Diesel till I die
OOF at its best again, excellent news :)
Migalot
Migalot
#85
James popped round today to do the cambelt, auxiliary belt, oil pressure switch and front brake discs and pads.
Was disturbed to find that the numpties at my local garage (where the cambelt was done 3 years ago) had managed to fit the belt a tooth out on both banks. Also, there was a tooth of slack in one section of the pulley belt which could easily have caused a failure. James was particularly unimpressed by the Tippex marks they had put on the pulleys – they clearly didn't use a proper kit. Add to that, they failed to reconnect the fuel sensor vacuum hose by the plenum. >:( >:(
Oh, and they had also dropped one of those plastic bungs under the plenum. I wondered where it had gone.
Won't ever use them again.
So pleased to have James correct everything. He's one hell of a good lad.  :y :y
Can't wait to have a drive tomorrow!  :)
Very welcome as always mate. I'll pop some specifics up later, but just off to catch last orders :y
I wouldn't worry about Tippex emphasising the correct marks on the pulleys, it's extra ones or on the backing plate that are cause for concern.
Quote from: Nick W on 22 May 2022, 07:56:52
Which were also present :)
It had clearly been done by eye and no setting kit. By someone unfamiliar with this V6 :y
Quote from: JamesV6CDX on 22 May 2022, 08:36:52
Mine was the same, and all four cams were a tooth out; clearly the previous mechanic(and I had the invoice for the work) didn't turn the engine through after fitting the belt. It ran a lot better being correctly timed, and the fuel economy improvement easily paid for the setting kit. I do add Tippex to the correct pulley marks just to make the job quicker
