Help! Error code P1700
Started by Migalot, 29 April 2022, 19:59:08
Migalot
As per subject line, I have a 2.6V^ auto with  error code 1700 which is a transmission fault, I think.
SWMBO used the car during the week for a longish, uneventful drive. When I went to move it yesterday, I got the dreaded engine warning light up. I turned everything off and a few goes later, the engine light went out and I re-parked the car. Today, I jumped in to go to the shops and was unable to get the light out and it appears to be in limp mode. Called the AA and the man got the 1700 code through the pedal test (his OBD reader wouldn't recognise the car!!).
The car has done 82k miles from new and had the transmission oil and filter changed aboout 15k miles ago.
Any ideas what the fault could be? Seems a bit terminal to me.  :'( :'(
If it were a 2.2 I would instantly say Cam Sensor.
However, the V6 tends to accurately report the Cam Sensor.
Any recent work done?
Migalot
Quote from: Doctor Gollum on 29 April 2022, 20:22:23
No, none. I forgot to mention that it (the engine light) has happened once or twice during the last six months – on both occasions when driving off after starting.
Is there a gearbox sensor that could be faulty?
GastronomicKleptomaniac
Anything going strange with the gearshift lights?
I don't know much about autos but could be something loose or broken underneath, connection wise...
If you have an Android phone I suggest that you pay £15 for a Bluetooth OBD adapter & download the Scanmyopel app (I think it was £7 for the full version when I downloaded it). Scanmyopel can read codes and live data from the engine, gearbox & ABS/TC ECUs.
The most common cause of gearbox codes are the selector switch or failed gear change solenoids.
Auto gearbox selector switch removal and cleaning
Migalot
#5
Quote from: Andy H on 30 April 2022, 08:48:35
Thanks for that tip.  :y
I have found this and eurocarparts are just 10 minutes away.
https://www.eurocarparts.com/p/streetwize-obdii-code-reader-for-android-and-ios-553999810
Migalot
So, thanks to the advice on here, I got an OBD reader and downloaded the scanmyopel app.  :y
I have the results and just need some kind member to interpret them:
P1605-08
Unknown Error
P0722-04
Output Speed Sensor Circuit No Signal
P0753-02
Shift Solenoid A (1-2/3-4 Shift) Circuit Low Input
P0000-00
Unknown Error
P0758-02
Shift Solenoid B (2-3 Shift) Circuit Low Input
P1500-08
Internal Power Control Final Stage Watchdog Error
P1625-02
Internal Power Control Final Stage Low Input
How does the car drive? Does the gearbox shift as expected?
Migalot
I haven't tried driving it for fear of damaging the transmission. Moving back and forth, it selects Drive and Reverse OK.
I live on top of a hill, so don't want to risk getting stranded!
Could it be a relay fault?
Migalot
Browsing online, I'm beginning to think it needs a new transmission inhibitor switch.
Migalot
#10
I'd never heard of an inhibitor switch before, but checking out images online it looks like the gear selector switch. Is that right?? Could be that AndyH was on the right track!
Anyway, if it is the same, I suddenly remembered that I had one from my previous pre-facelift 2.5 in my shed. I've dug it out and wondered whether it would work on my 2.6?
Can anyone confirm? I think the part number is 1 348 06248A.
It's the same gearbox  :y if you have one it's worth a try and report back.
Migalot
Quote from: Doctor Gollum on 30 April 2022, 17:34:15
Will do, Doc!  :y
biggriffin
Just clean the selector mechanism, there's a guide.
Hoof'land storeman.
#14
Quote from: biggriffin on 01 May 2022, 08:31:59
It isn't a complete guide - I grabbed the images from peoples posts when they were grappling with selector switch problems.
The first task is to check that the indicator lights on the gear selector console match the position of the lever. Clear the codes and see if any reappear.
If it is the switch at fault then you should be able to take it apart and clean/regrease it. the fun part will be getting to it  ::)
and adjusting it correctly when you refit ......
