Recommended brand for X30XE head gasket set
Started by Derek_in_Penzance, 05 May 2022, 12:07:03
Derek_in_Penzance
Hello guys,
What brand(s) of head gasket set are recommended for an X30XE head job? I know that Victor Reinz are one of the best, and I believe original equipment, but what thoughts does anybody have about Payen, Ajusa, Glaser etc? What is recommended and what is best avoided?
I'm sure this must have been discussed in past threads but I can't find any.
Many thanks for any advice.
Go to Facebook and become a Fan of the GM6 Spares Facebook page. Omegas dismantling, mail order parts & servicing. Tech 2 services available.
I used Elring on mine. They were still good when I sold the cars several years later.
I would have no problems with Payen or Reinz, although I tend not to worry about brands.
So why did I choose the Elring head set? Easy, it was £12.50 off Ebay :y
Don't forget to buy a new set of head bolts.
biggriffin
Quote from: Nick W on 05 May 2022, 12:55:42
I just reused the old ones.
Hoof'land storeman.
Derek_in_Penzance
Thanks for the advice. I think with alloy heads new head bolts are a must. I have reused old ones on my own cars with no issues that I'm aware of but it's a bit risky.
456lbft
Quote from: Derek_in_Penzance on 07 May 2022, 13:17:05
I believe if they are stretch bolts, which are usually torque + angle set, they should be replaced with new ones.
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
It's not the head material, but that of the bolts which are torque to yield. I recently made some parts out of used Rover K-series bolts I hadn't thrown away, and on measuring found that a 20mm length above the threads was nearly 1mm smaller diameter than the rest of the bolt. New ones are the same diameter along their entire length. I've always been dubious about reusing them, now I wouldn't even consider it. Bolts are the cheap part of the job anyway.
Derek_in_Penzance
Agreed.  When I reused old bolts it was on a cast-iron head on a six-cylinder CIH Monza engine. Tough as nails with head bolts the size of treetrunks. Not ideal, but no repercussions. On the X30XE job I am doing now I will use new bolts and would not consider anything else.  As for the gaskets, I asked because I have seen that some brands of gasket can be rather poor quality. Thanks for the advice.
