F/S - Kent Moore KM-800 V6 dealer engine timing kit and 30mm roller spanner
Started by sjc, 27 May 2022, 17:29:53
sjc
This is the genuine main dealer tool kit, not to be confused with the budget tool brands.
To anyone not in the know, this kit is essential when changing the timing belt on the Vauxhall and Saab V6 engines and covers the full range - Omega, Cavalier, Calibra, Vectra, Sintra, etc. and the Saab V6 models too.
All 5 components of the kit are present and correct - 2 x cam locks, crank holding/position tool, belt wedge (stops the belt slipping off the crank while you fit the rest of the belt) and the cam timing gauge.  Also included is the proper Kent Moore roller adjuster/holding tool which is basically a 30mm deep offset spanner.
Complete with original carry case.  £60 plus postage.
sjc
