Hi friends need cid programming
Started by ramzyharb, 03 June 2022, 00:47:28
ramzyharb
My opel omega v6 2.6 i need cid programming
Fuel consumption correction whats i will choose
1.0
1.2
1.5
Whats is correct on my car  :(
Sure its a CID, as I thought the CID didn't have a correction factor, just that its correctly programmed for car spec.
MIDs do have a correction factor.
Those that have a correction factor, you should program the display to the cars spec, and if the fuel computer is out, manually work out by how much, then set the adjustment to match.
