3.2 auxiliary water pipe wanted.
Started by Mutha Jugs n Speed, 06 June 2022, 15:50:02
Mutha Jugs n Speed
Another one of my shot in the dark posts ::) looking for the hose that comes from the bulkhead and connects to the auxiliary water pump on the drivers side inner wing. Unfortunately the top end of the hose has a push/pull connector, which makes a Billy Bodge it repair awkward.  ???
Number 5 if it is the hose from the bulkhead to the pump.
Mutha Jugs n Speed
Yes many thanks, both correct.....part number 9 129583, other pipe looks the same but can't read due to fading. ::)
Mutha Jugs n Speed
Just had an ebay seller quote me £150 for two used pipes, why?? because he says they are unique to the car WTF!!!
Mutha Jugs n Speed
Mutha Jugs n Speed
Also noticed that there's no quick connector on that item, so does that mean the old connector can be removed from the leaking pipe?
Mutha Jugs n Speed
Thanks Al, got a feeling that there won't be any V6 items there, but I'll give them a call, and see if he has any suitable ones kicking around. :-\
biggriffin
Will check when I get home at weekend, can't promise anything.
Hoof'land storeman.
Mutha Jugs n Speed
Thank you  Big G and Dr G, hopefully I can solve this one....just might take a bit of time as there's not much out there at the moment. :-\
biggriffin
You can use a piece of hose and jubilee clips.
Hoof'land storeman.
