Author Topic: Mechanic reccomendation or volunteer  (Read 3901 times)
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
Re: Mechanic reccomendation or volunteer
« Reply #15 on: 07 September 2008, 19:57:41 »
What speed do you drive at to get 40mpg?
Best I've ever got was about 32, and I was delighted with that.
« Reply #16 on: 07 September 2008, 20:01:14 »
my Pug 605 3.0 V6 would do a lot more MPG at 90 than it would at 60.
Unfortunately, same doesn't apply on the Omega - slower speeds see better returns. Between 65-70 is most efficient in a V6, IMHO.
chrisdb
  • Chesterfield
« Reply #17 on: 07 September 2008, 20:01:19 »
Constant 75. I do stretches of about 60 miles at a time. But I do find if I come off cruise and wander up to 80-85 it does not make too much difference - drops to maybe 37-38...
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
« Reply #18 on: 07 September 2008, 20:06:09 »
I managed to get 40 mpg only with a 4 pot 980 Kg clit  :-/
« Reply #19 on: 07 September 2008, 20:06:32 »
You must be going downhill with a tailwind all the time!!! I cruise at an indicated 75 (actually 72) and normally get low to mid 30's on a run!!!
jereboam
  • Suffolk
« Reply #20 on: 07 September 2008, 20:09:38 »
75-80 seems to suit my car best, and I leave it on cruise control because otherwise it goes to fast - nothing to do with me  :) - it just wants to go faster.  I can't say if it uses less petrol at 65-70 - never really considered driving at that speed  :).
But my impression is that there's not a great deal of difference in the consumption between 50 and 90 - neither of which I do for extended periods if I can help it.
What's truly horrendous is the 17mpg I get if I just use the car for commuting 3 miles twice a day  :(.
« Reply #21 on: 07 September 2008, 20:12:35 »
Thats because the pug engine has a shite inlet setup and no low down torque so it needs revving to get to an efficient point in the engines operating range!
MutantCav
  • Gainsborough
« Reply #22 on: 07 September 2008, 20:35:27 »
Cats bolts are easy to get at...you can jack up the car high enough using the standard Omega jack...jacks up higher than a trolley jack...2 16mm bolts holding cats in place although people put different sizes on sometimes just to be bloody awkward!! Need some extension bars long and a short one combined...16mm socket also happens to be the 10mm spark plug socket and is ideal for getting up to the nut head over the bolt sticking out...
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #23 on: 09 September 2008, 20:31:26 »
i don't go by speed, i watch the revs.....
at 2800 rpm (75 mph) i can get 35 mpg 3000 rpm (79 mph) its down to 32 mpg and at 3200 (81 mph) i am down to 29/30 mpg
Ian_D
  • York
« Reply #24 on: 09 September 2008, 23:51:21 »
Take it its not an auto then  ;D
[size=12]
Ian_D
  • York
« Reply #25 on: 09 September 2008, 23:55:19 »
You're getting 40mpg?  :o
I've just been to Devon and back - averaged 29.3 on a steady run!
Yes, 40!! I used to get 30-31 on the motorway and then it would drop to around 23 when I hit town. I've done a lot of work getting things fixed and a couple of weeks ago changed the cam cover gaskets as the plugs were drowning. MarksDTM changed the fuel filter for me because I didn't have the special tool. Now I get 40 on the motorway, and it drops to 35 around town :y
I have never, ever managed to get a consistent 40mpg out of a 3.0.
I've done it in a 2.5 driving like miss Daisy - but never in a 3.0!!
Have you tried this... get to 75 and hold it on cruise, then reset the Ave mpg counter?
I have no idea how you get them MPG readings... Has your car got the wrong MID screen fitted?  ;D
If I reset mine at 75, it does 34mpg. Due to schools starting, my cars mpg from home to work (about 3-4 miles) is now 15mpg on a good day  :o (have seen 12mpg before door to door :'()
[size=12]
chrisdb
  • Chesterfield
« Reply #26 on: 10 September 2008, 09:41:50 »
Next week I'll measure it against distance to get a 2nd reading and I'll let you know :)
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #27 on: 10 September 2008, 16:05:36 »
Hell 40mpg (you must free wheel alot)  :) even on my bestist behaviour using a "featherlight touch " er mmm I cant get over 35mpg when watching readout on dash it says that when doing 50-60 mph but once over the 60' mark it drops considerably, are you sure some neighbour isnt adding fuel to the tank for you like an old movie I saw with Walter Mathieu ;D ;D
