VW Passat jamming seatbelt
Started by grifter, 31 August 2022, 07:32:43
grifter
Hi All
Just wondered if anyone has or had one of these cars, it's my brother's car (2014 plate) and the drivers seat belt is doing his head in, it keeps locking when he's trying to pull it on. He asked VW about a new seatbelt and they said they have them but are about 360 each just for the part, so problably 500 all in plus fitting.
I'm pretty sure this is one way i.e sealed unit and not able to fix. The VW garage said bring it in and they can check it, but imagine it's a new seat belt it would need.
Thanks
G
It will need removing to investigate. At which point bolting in a new one will be quicker than prodding and poking at the broken one.
If summat has failed you won't be able buy the failed part, even if you access/replace it.
Factor in any airbaggery related wiring etc, you may as well just get a new one.
Yup, I would replace.  Not necessarily with a brand new one if you can find a good one the right colour.
Rangie
Had exactly the same problem on a Hyundai Terracan, replaced the complete unit as it was driving me crazy, from memory it was around the £300 mark.
Wife's astra was doing it, only when the weather was hot, strangely. It was ok once halfway out.
Couldn't be arsed to give it to Vx and local garage said they couldn't find anything wrong.
So I pulled it half out (not fully halfway, just half travel of the normal use) and fitted two of these to stop it fully retracting. A bodge, yes, but it works.
https://www.amazon.co.uk/Newseego-Adjuster-Seatbelt-Comfortable-Experience/dp/B07F2V9WW2
Diesel till I die
Diesel till I die
Quote from: STEMO on 31 August 2022, 17:26:30
Quote from: Doctor Gollum on 31 August 2022, 17:22:35
Until the airbags go off :D
What??
It will prevent the pretensioners from doing their job effectively, so if the airbags deploy, they won't protect you to the same level.
Quote from: Doctor Gollum on 31 August 2022, 17:34:22
What??
What difference is two, or one, small plastic clip at the front of your right shoulder going to make to the pretensioners? Plenty of room for the seatbelt to grab you.  ::)
Diesel till I die
The pretensioners have limited travel and become ineffective if the belt is slack.
Ask your insurers if you're still covered if you have your doubts ;)
Quote from: Doctor Gollum on 31 August 2022, 17:53:03
I have no doubts whatsoever. Go and watch a nice conspiracy theory video, instead of posting on every single thread just for the sake of it, there's a good lad  :)
Diesel till I die
Quote from: STEMO on 31 August 2022, 18:15:11
That's rich ;D
Quote from: Doctor Gollum on 31 August 2022, 18:54:05
That's rich ;D
Have a count up, lad  ;)
Diesel till I die
Migv6 le Frog Fan
I had the same problem with the drivers seatbelt on the Boxster. A quick squirt of WD40 into the mechanism seems to have cured it.
Quote from: Migv6 le Frog Fan on 31 August 2022, 19:08:59
The astra mech is buried inside the lower door trim. I thought about removing the door rubber and prising bits of trim off, but the clips seemed much easier  ;D
Anyhow, now that it's cooler, it works fine....and it will probably be gone before it gets hot again.
Diesel till I die
