12V Pumps in Cooling System
Started by polilara, 28 September 2022, 17:21:43
German  ;)
BR is Brün
GR is Grün
Ergo BRGN is BRown with a Green trace
DK would be Dunkel but haven't seen it used on the Omega diagrams
polilara
Strange, my colors do not match but they are from real life.
Homework part 2:
Engine hot, cabine cold, set point HI, auto pressed, ignition off
0.4V in second pump
and when air condition off but ignition on
0.4V
and when air condition off and ignition off
0V
So if no relay bad contact somewhere, if relay the perhaps broken relay.
Quote from: polilara on 29 September 2022, 18:57:09
Homework part 2:
0.4V in second pump
0.4V
0V
Just to confirm, 2002 2.6 Scandi market car?
polilara
Yes, 2001 and bought here when new, 2 6 Elegance with winter package, LSD etc. I can send detais based on frame number tomorrow. Had this car almost 19 years so I know it pretty well.
VIN will be of little use to me ;)
Coolant pump confirmed as BlackBlue/Brown :y
Fed directly from the climate panel Pin19 of X63 (one of the two plugs into the climate panel)
For identification purposes, Pin1 on X63 is Red... Pin1 on X64 is White :y
Runs via X3 Pin17 and X30 Pin3.
These are both the big round plugs next to the battery. X3 is run from under the scuttle. X30 is the main engine harness plug.
polilara
OK, thanks, have to study starting from the pump side, alredy saw yesterday evening that the cable from pump goes first to front and then turn left, goes under radiator and then turns left (back) in front left corner. Then it climbs up towards main relay box. If i understood right X30 is the first one from this direction; from pump to climate panel.
polilara
Many wires...; some help still needed.
So X3 and X30 round connectors, are they those in my pic. below?
, most left one is empty? Anyhow, I did my best but I think that the wire from that pump below expansion tank goes to relay box. Can I be that wrong? Eleven relays. I checked that earth is OK in the pump connector and allways when iginition on I get 0.4V to plus.
You also have the pin numbers.
The other round plug is X4 from memory. Currently about 800 miles from my diagrams.
You have the wire colours and pin numbers for each connector.
All that's left to do is physically identify the wires at each point and check them for continuity end to end and ground from each point working back from the aircon panel.
Short of actually turning up at your house, I'm not sure that I have anything else to add :-\
polilara
Thanks DG for your patience. I might have followed wrong harness, new trial today. Actually all wires go inside neat plastic tubes connected to each other with isolation tape, no physical damages seen anywhere. Let's see what I find.
You can test the wires for continuity and resistance via the plugs. Any wire with a resistance value of 1or no continuity is broken.
Any slight resistance above zero and intermittent continuity suggests a damaged wire.
Either way if the wiring checks out then the problem is within the climate panel.  :y
polilara
Sure, thanks. Climate panel would be another point to start today. Found this
http://www.omegaowners.com/forum/index.php?topic=90507.0
So radio and cage out. Do I just then have to open those two screws to take climate panel out. I do not undersrand where it "dissapears" in this case. I ask just to avoid romving parts which are not necessary to take out when removing climate panel.
Quote from: polilara on 04 October 2022, 16:13:19
Ashtray and radio out and remove the two screws in the top corners. Then lift the trim away.
No need to remove the plugs for the switches... Once the trim is free of the dash you can access the clips that secure the climate panel and also the plugs. Use the wire detail I posted to identify the correct plug for testing.
polilara
Thanks DG, I proceed during weekend, let's see...
