Author Topic: Shock went into the boot  (Read 14566 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: Shock went into the boot
« Reply #15 on: 29 November 2022, 08:00:53 »
So.....I dont't know how you call this profession, but I took omega to the shop, where they took measures for turret tops and will make them from 2mm thick bent and welded sheet metal. The owner - very old bloke, was surprisingly impressed by omega and othervise rust free body of it.
But, there's always a but....body shop which will replace turret tops is fully booked until the middle of January.
jimbo1977
  • lincolnj
    • omega 2.2 manual
« Reply #16 on: 09 December 2022, 22:05:52 »
ive now got a urge to go and check around my rear shocks now !!  :o
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #17 on: 10 December 2022, 10:26:04 »
yes good idea.
i did mine a while back. just some surface rust and dealt with accordingly.
but that how it all starts !
anyway a bit cold for playing out today !
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #18 on: 10 December 2022, 16:40:46 »
Have to check mine, too. Actually how cold you have if cold?
danzigfan
« Reply #19 on: 10 December 2022, 16:59:00 »
It was also only surface rust on mine when I restored it...
cam.in.head
  • West yorkshire
« Reply #20 on: 10 December 2022, 21:43:07 »
getting the rust off is important. forthis or ANY repairs.
for years ive used rust killers and they only work to a degree but now recently been using the only permanent solution.
a mini sandblaster gun. why i never thought of it gears ago i dont know.bit fiddly and slow but does work 100%.
various other methods like gels and the like but sandblasting rusty areas works for me.
then obviously paint and protect it thoroughly(after repairing anything if found !)
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #21 on: 10 December 2022, 23:03:52 »
Around -4 degrees, which is probably a summers day for you.  ;D
polilara
  • Finland
« Reply #22 on: 11 December 2022, 18:15:23 »
Ok, thanks -4 is really too cold for maintenance outside. Just checked that London had today around zero, didn't know that you can have such weathers. We had colder than -10  already in November here in west coast where I live. In Lappland they already have had more than -20. Summer in Finland is usually ok, not too hot, yes and no snow...
