Wheel Refurbishment
Started by Sir Tigger KC, 28 November 2022, 21:37:17
Quote from: Doctor Gollum on 28 November 2022, 23:19:55
Quote from: Sir Tigger KC on 28 November 2022, 23:18:30
These are they!  :y
Well a set of those would more than double the value of the car I suppose....  ::)
And they won't leak ;)
If I end up spending that sort of money on new wheels they'll come with a car attached!  :-X  ;D
johnnydog
I would never use 'goo' (not the lube to install a tyre) to attempt to repair or seal a leaking / faulty rim - tyre fitters nightmare apparantly.
There are wheel refurbishment places near me that say they can remove 'up and down' flat spots on alloy rims, as long as it is a gentle indentation rather than a severe crease. The weakest point of any wheel is the inside rim which is furthest away from the spokes (thats one reason why you shouldn't straddle individual speed humps too fast, especially with low profile tyres as this puts extra stress on the inside of the rim which is the weakest point... :y). They use wheel straightening machines, which locate the defect in the rim, and then hydraulically remove the twist, flat spot or indentation returning the rim back to being perfectly true. This is normally done as part of the refurbishment process, but I'm sure it could be done purely to straighten a rim that didn't otherwise need any cosmetic repair.
Quote from: Sir Tigger KC on 28 November 2022, 23:30:54
These are they!  :y
A decent refurb is £75 per wheel, give or take.
I have used these guys to good effect...
Wheel Works
01293 907663
https://g.co/kgs/9gDx1W
They made the wheels on The Barge look like new. Although it doubled what they cost to buy in the first place.  :D
And apparently they do Mondeo wheels  ;D
GastronomicKleptomaniac
In my limited experience, wheel refurbers respond well to persuasive negotiation on price. Especially when someone turns up with a wodge of paper money. :y
Quote from: Doctor Gollum on 29 November 2022, 00:02:01
These are they!  :y
Round here, that sort of money gets a wheel chemically stripped, minor gouges filled and the whole wheel painted the same colour.  It's more of a tart-up than a refurb, and certainly doesn't include any straightening or crack repairs. Those are extra, and are priced on a per job basis. And as previously mentioned, the closer any damage is to the mounting face, the less likely a repair is to be successful.
I know of cheaper firms, but they're just sanding, filling and repainting wheels which is what the car dealers want.
amba
Had a fairly major buckle on an Irmscher wheel on previous car done by Lepsons at Gillingham .Kent.
Would regularly loose air over space of few days and as you got really fed up keep pumping it up at all hours of the day.
Lepsons is quite Old School and will repair or refurbish as required and they also offer collection and delivery but imagine the costs to Dorset and back would be pricey...but just my experience they did a very god job
Migv6 le Frog Fan
biggriffin
The price you'll pay for 1 refurbishment you could possibly buy a set of 4 from eBay, gumtree, FB.
Hoof'land storeman.
Migv6 le Frog Fan
Actually, this reminds me. The n/s front on the Omega has always lost a couple of psi per week since I bought the car.
Had a few tyre changes, including cleaning up the rim, but its still the same.
Got to do front discs / pads next week, so must remember to try and find where it leaks from while the wheel is off.
ronnyd
I paid £50 a corner to have mine cleaned and reseated. Must say that it certainly done the trick.  :y
Migv6 le Frog Fan
Quote from: biggriffin on 29 November 2022, 10:16:06
Not for that type. The ones in the link I posted need a refurb and they are £750.
I dont particularly like them tbh, and they are a pig to keep clean.
Might look at doing a swap with a set of more standard type of wheels, once Ive worn the tyres out on these.
Something like this.https://www.ebay.co.uk/itm/334635051143?epid=1316399118&hash=item4de9cda887:g:tmkAAOSwp2ti5twA&amdata=enc%3AAQAHAAAAsHHh9m155R5MaMZr5D7gbqQswlIQSTojLoNW77WkiZUmRqB7Hu5%2BBTqVgzu%2FssPsaKFEMTJb3Ob%2FY2LxEanHCdaeZQ5ogr3oo694A3mvduHfmsQBVNu0VDN8xSMhSzEzxi77vM1YvIKkQfpmPxqrvOPqJ51aQvAAOSFPMGW0QuZwYtPvSZekTXrhsCAvAtoqw1GQnyqZWW%2Bj3x0rPPdz1VleD81%2BM%2Fv5RGD4m0U2o5ii%7Ctkp%3ABk9SR8qMva6YYQ
Easy to keep clean, and to repaint when needed.
Quote from: Nick W on 29 November 2022, 08:34:22
These are they!  :y
Wheelworks pricing is pretty transparent  ;)
Quote from: Doctor Gollum on 29 November 2022, 10:27:10
These are they!  :y
Welding is an extra £35+ per wheel and straightening is £20+, so if a wheel is cracked and bent, then you're looking at another £66 on top of the refinishing ;)
LC0112G
If you're looking for someone local, and are prepared to risk north of the border, then I've used these before https://www.wheelshine.co.uk/
They're located on the trading estate just south of Yeovil Town Football club. I've had my Omega and LC wheels done by them, and one buckled omega rim repaired.
Quote from: Migv6 le Frog Fan on 29 November 2022, 10:12:49
The wheels on the Boxster could do with a refurb, but its unlikely to happen.
20 bolts per wheel that often snap on removal, and I believe they are around a fiver each,
Thats before the actual refurb cost.
I have always done my own up to now, but not easy to do with these.
https://www.ebay.co.uk/itm/275097496470?epid=1916390905&hash=item400d16ab96:g:cQcAAOSwXqhh2YBN&amdata=enc%3AAQAHAAAAwMT65dSb%2FjZQ3%2FCPjtt6n9JUQ9KQgtsmJT37IwFIiHW6KR0NGegstS3ovcFT0GLKuZvp3Bgy3VYsuA017YXlmJtuweEyNbPwkUETUFi22nLGw2Gh5JA1zk9d9cNCmR7tFciqeAc3iDmnmFcA%2FLKtMDs6%2Bv0%2F1BZm%2BIvplVwUhZpeUsX%2BM6zq%2FBmQ%2Brs8v%2B02h9v3LcUAwUQdbf32fpiwDGR5qTBvh37IPBXLHA5qrVdEl2amaoS2UwtAXEFP4B0CTg%3D%3D%7Ctkp%3ABk9SR4jN4a2YYQ
Bet you could get away with 12-14 bolts easy, doesn't matter if you snap a few  ;D
Diesel till I die
