Wheel Refurbishment
Started by Sir Tigger KC, 28 November 2022, 21:37:17
I'm getting fed up with my leaky rims on the Mondeo, having to check the tyre pressures regularly and the odd spontaneous flat which typically happens in the pissing rain.  ::)
So after having to fit the spare on Saturday arvo (yes in the pissing rain), I examined the rim carefully yesterday and after pouring some water I noticed in one place where the bubbles were coming out, a very slight flat spot in the rim.   :-\
So the question is.... Would a refurb fix this?  ???  :-\
TIA!  :y
dave the builder
empty /release the air ,then ,stick a can of slime in it  :P
A GOOD tyre fitter would break the bead, clean up the bead area, put some decent bead sealer on ,set it back on the bead, leave it low pressure for an hour, then put it to full pressure .then test it for leaks
NOT a "5 minute ,while you wait job "
Fix
Often
Repair
Daily
Quote from: dave the builder on 28 November 2022, 22:02:04
Fix
Often
Repair
Daily
Found
On
Roadside,
Deflated.
Fix
Often
Repair
Daily
A few years ago I had all of the tyres removed and the rims cleaned up to no avail, and every time I have had new tyres I've mentioned the leaky rims and asked them to clean them up, but they still leak  :-\
I've got used to checking the pressures regularly, and always check them before a long journey, but getting fed up now so thinking about biting the bullet and having them refurbed, but there's no point if this flat spot can't be fixed.  :(
The flat spot is imperceptible really. About an inch, and the gap between the rim and the ridge on the tyre widens from about 5mm to 8mm, but that's where the biggest leak is.  :-\
dave the builder
Quote from: Sir Tigger KC on 28 November 2022, 22:19:47
Fix
Often
Repair
Daily
I said GOOD tyre fitter  ;D
take it somewhere else
Quote from: dave the builder on 28 November 2022, 22:27:03
Fix
Often
Repair
Daily
I've taken it to various tyre shops over the years.  :-\
Maybe I should just chuck a can of goo in.....  ::)   ;D
Quote from: Sir Tigger KC on 28 November 2022, 22:33:01
Fix
Often
Repair
Daily
That's what I would do.
Diesel till I die
dave the builder
Quote from: STEMO on 28 November 2022, 22:34:05
Fix
Often
Repair
Daily
WTWTCH  :y
if it doesn't work then you have a flat tyre  :P
Quote from: dave the builder on 28 November 2022, 22:39:56
Fix
Often
Repair
Daily
WTWTCH  :y
Mmmm... I've also got the ABS light on which I reckon is the module and the windscreen washer pump has packed up properly this time, so I don't want to spend too much on it.  :-\
I had a quick look on ebay for a 2nd hand rim, but they all looked just as scabby as mine.  ::)
Bite the bullet an buy new wheels. Probably no more expensive than the used shite on ebay ;)
Quote from: Doctor Gollum on 28 November 2022, 22:52:01
Ha that'd cost more than the car is worth!  ;D
Quote from: Sir Tigger KC on 28 November 2022, 23:07:42
https://shop.ford.co.uk/collections/set-of-alloy-wheels
Possibly, £675 ish for a set of "16s if they'll clear the brakes  :-\
These are they!  :y
Well a set of those would more than double the value of the car I suppose....  ::)
Quote from: Sir Tigger KC on 28 November 2022, 23:18:30
These are they!  :y
And they won't leak ;)
