drivers door catch/mechanism
Started by cam.in.head, 01 December 2022, 18:12:34
cam.in.head
hi to all. im looking for a drivers front door locking mechanism/catch.
mine wont let me in !
(dont need thesolenoid)
many thanks.
cam.in.head
if not il get a saab one off ebay .plenty of them available
The Omega one is unique to the Omega/Catera ;)
cam.in.head
i was told the saab one is the same by a member here.. certainly looks identical in every way. ?  so have ordered one to see. i can always relist it if not.
If it works, happy days ;)
The thing you want to consider is any difference, however apparently subtle could be the difference between getting out or not in an accident.
cam.in.head
i intend to fix my original but having a spare on hand if not fixable. have messaged the other member to confirm details or differences if any. will report back.
Quote from: cam.in.head on 02 December 2022, 17:16:50
It will be good to confirm because the failure rate of the Omega ones is only getting worse  :y
cam.in.head
lock mechanism changed today. the old one had failed as predicted by another member (the release 'cog' had virtually fallen off its shaft after wearing its oval centre away.)
the saab  one is fitted and looks identical in every way. works perfect.
cam.in.head
the one i put on had its cog very securely inplace .my guess is that seeing as they are only an oval section of shaft with an oval hole in the cog and burred over,this method of attachment is prone to work loose eventually.
in summer i will check the other locks and add a blob of weld if any signs of looseness.possibly worth doing anyway even if not loose yet !.
i have repaired my old one with a weld and it also needed a small tube inserting over the shaft too as the hole had worn a bit too where the shaft goes through.possibly never need it but its done just incase.
dave the builder
Now some parts are hard or impossible to get I guess such "repairs" are the way forward , well done  :)
cam.in.head
thankyou.
everything is repairable (within reason !) its all part of the fun of being a car nut !
