fault codes update
Started by raywilb, 03 December 2022, 15:29:07
raywilb
i got thinking that when i initially filled the ad-blue tank with 10ltrs the urea light went out, but when I
raywilb
Quote from: raywilb on 03 December 2022, 15:29:07
i got thinking that when i initially filled the ad-blue tank with 10ltrs the urea light went out, but when I read the tank holds 17ltrs & I filled it to the brim thats when the UO29D code appeared & eml stayed on . today I took 3ltrs back out & that cleared everything. by over filling it I guess i confused the sensor  happy now :y
ronnyd
What made you put so much in Ray?  ???
raywilb
Quote from: ronnyd on 03 December 2022, 16:10:28
because i read on the french forum it had a 17ltr capacity so surmised it wanted a top up.  now i know . lesson learnt  ::)
ronnyd
Quote from: raywilb on 03 December 2022, 16:32:21
You could have just pissed straight into the tank Ray.  :D
YZ250
My Audi holds 17 litres, I just wait for the 1500 mile warning to pop up and then I shove 10 litres in.
Mines a bit of a glug, glug glugger to get in so it pisses me off doing it. I did consider stabbing a hole in the base of the container to let more air in but then it would probably piss back out all over my car.  ;D
raywilb
Quote from: YZ250 on 03 December 2022, 16:40:47
i have bought a  5ltr pouring jug from toolstation foe the job ,works well
ronnyd
Quote from: raywilb on 03 December 2022, 17:50:11
Has the tank got a level plug or line as a visual? But, knowing French cars ,it's probably buried in the depths of the engine bay, far removed from daylight.  :)
Quote from: raywilb on 03 December 2022, 15:38:21
You're welcome  :D
raywilb
Quote from: ronnyd on 03 December 2022, 18:10:50
no nothing  like that . the fusebox in the glove compartment is a nightmare as found out when trying to check if it was a fuse fault
I've yet to see any kind of warning on my Merc for Adblue ..... I've done around 30k & have only ever put a gallon in as & when-ever. I once, unintentionally brimmed it.
Quote from: Andy B on 03 December 2022, 22:07:34
They get a bit sensitive to low levels if you ignore the warnings.
Quote from: Doctor Gollum on 04 December 2022, 00:28:02
Quote from: Doctor Gollum on 30 November 2022, 01:31:33
Could that be as simple as needing a DEF refill :-\
;D
General consensus is most DEF equipped road cars use about a litres of the shite for every 500-600 miles.  Guessing your ML isn't quite as economical on the lorry juice as most cars, so not sure if it uses a bit more DEF.
Her car has a tiny pigs piss tank - 9l I think - so gets half a Screwfix/Toolstation (whichever is cheapest on the day) 10l can as soon as it starts moaning,
I deliberately chose my car because it doesn't have DPF or piss tank.
Will pay the price for that if Captain Underpants gets his way extending the ULEZ to include Heathrow  :-X
