What has P*ssed you off today?
Started by Varche, 02 January 2023, 18:25:56
Quote from: LC0112G on 30 June 2023, 15:04:19
Damn and blast. Just been out to get some stuff out of the boot of the LC and discovered the rear number plate light housing is gone. Don't know if it fell off of it's own accord or some scrote has nicked it. Not sure if I've got a spare either.
And I'm guessing spares for them are getting scarce one.  Although the numberplate thingie is prob standard Carlton?  Although I bet they are still scarce ;D
Diesel till I die
Quote from: TheBoy on 30 June 2023, 15:06:32
If Carlton/Omega A spares are available in Brazil, I can always take an empty suitcase...
countrywoman
Used yet another 10L bottle of Argon welding the intake pipes for the Austin, where the one joint is of the same alloy it welds easy but the smaller pipe that fits to manifold is of a harder alloy and a right bar steward to weld neat. ended up using loads of filler rod and gas and at £70 for 10L is getting costly.
Raeturbo
Rubber and jubilee clips 👍
Laying a rubber road.
Quote from: Raeturbo on 30 June 2023, 21:01:23
OOOOO.....you kinky barstard  ;D
Diesel till I die
Rangie
My  fix anything are WD40 & Cable ties ..👍
Raeturbo
Quote from: STEMO on 30 June 2023, 21:19:01
  You are awful... but I like you💋💋👠👠
YZ250
What pissed me off was the Mini in front of me that kept stopping to let people out of side roads, even though we were travelling on a 60mph stretch of 'A' Road. There's politeness and there's downright stupidity. This was downright dangerous. He/She got the message in the end when I nearly rammed them.  :)
Raeturbo
Olympia5776
Sometimes the wet blanket of defeat wraps itself around you and says " just give up I've won."
Took Omega for it's NCT test ( MOT) two weeks ago , failed on high idle .
I couldn't understand it as it has done 280m since last test .
Anyway , went through it checking exhaust , replaced plugs /airfilter even though they were new , replaced maf with a new spare I had ,had changed oil and filter and then tipped a bottle of Catclean into the low level of fuel in tank.
€54 down drain for test and another €28 paid up front for the retest + the parts .
So confident was I that I taxed the car for three months (€200 ) and then booked the retest for today .
Took it out last night to run it at high revs to get the Catclean to work .
All went well with it driving beautifully until one mile from home when it stuttered nearly cutting out  and the eml came on .
Put the spare gallon of fuel into tank to reduce the concentration of mix in there and she started ,albeit with eml on , and drove home .
Tested it and codes for cam sensor ,crank sensor and ignition coil primary/secondary circuit ''''ed ..
Cleared codes but cam sensor came back on and would not clear. Crank sensor was renewed less than 150 miles ago.( bitch of a job on the x20xev )
Spent the morning chasing a cam sensor with zero luck , all the suppliers ( many )  had it NLA  even the MD had it NLA although they wanted €244 for it if they had one .......
Lost my NCT slot and forfeited the charge .
So there we are,not a cam sensor available in IE, dead car in garage  fully taxed and insured  . I had to reduce myself to buying one from Amazon with the wait for it to arrive .
Spending too much money on it now for the minsicule miles I am doing in it so it looks like the end of the road with me is nigh after 22 years .
Raeturbo
Don't worry after you fit the new one all will be well again👍
Olympia5776
I wish that was true .......
New car order cancelled due to colour choice being discontinued . >:(
Unable to order new VW of choice due to model being replaced . >:(
Newly installed manual gearbox in BMW removed and back with specialist to rectify non selection of reverse .... >:(
Blackpool Illuminations on Yeti due to front ABS sensor failed  >:(
I don't think I've ever had a run of bad luck like this with cars .........
Fukinell, Don  :o At least things can only go one way from here, I think hope.
Diesel till I die
Avoiding VAG products could be a start. :-\
