UO20D CODE
Started by raywilb, 03 January 2023, 22:21:22
Quote from: Marks DTM Calib on 09 January 2023, 07:50:34
Needs changing, or your trip will be a wasted one  :y
ECU and sensor? Or just one of them?
Quote from: TheBoy on 09 January 2023, 07:57:59
They are a combined part and ship as a set, the ECU is apparently calibrated to the sensor:
Yeah, what could possibly go wrong with that setup ;D
So a device designed to save the planet actually causes more harm due to such a daft design. Quality.
Quote from: TheBoy on 09 January 2023, 08:10:15
From what I am told, if you crack the top off the ECU once they are a few years old, there is loads of water damage as they are not well sealed (in fact looking at the casing retaining method, its not surprising!). So when they get wet they have a wobble, eventually the wobble turns into a permanent fault
henryd
Yeah ,lets strap a small ecu to the floor of the car 6 inches off the ground, what could possibly go wrong ::)
other rides
