UO20D CODE
Started by raywilb, 03 January 2023, 22:21:22
raywilb
 the dreaded UO20D code appeared again today so deleted it again & once deleted alls OK for quite a while . my query is knowing its a communication code does BanK 1 refer to the sensor ??     wishing all oof members all the best for 2023  :y
It's a straight four pot. Having Bank 2 pop up would be something of a surprise  ;)
raywilb
Quote from: Doctor Gollum on 03 January 2023, 22:55:01
ok ,  not as knowledgeable as you fellas but i will have a go at most things . i will take it & get the nox sensor checked out
I think thats a DPF pressure sensor generic code, needs reading with a tool more customised to the Manufacturer to get the sub code and more detail
raywilb
Quote from: Marks DTM Calib on 04 January 2023, 08:38:13
sorry to all the code read UO29D  not 20
Quote from: raywilb on 04 January 2023, 13:05:12
Just had a little chat with a PT contact here.
Apparently Shitroen use the very poor Conti NOx sensor setup which has a sensor and mini ECU located close together, he says the ECU is very pronce to water ingress and is likely the issue. Apparently they come as a matched pair (ECU and Sensor).
Being a NOx sensor it should easy enough to get at and change, the cost however might be a few hundred quid for the part
raywilb
Quote from: Marks DTM Calib on 05 January 2023, 08:25:08
Y
raywilb
Quote from: raywilb on 05 January 2023, 21:08:05
I did once mention about it first happened after driving through water , no garage near me want the job so next Tuesday i am taking it to Wakefield to a guy thats really good with the computer analysing.
Who will tell you that the NOx sensor has had a fit...
raywilb
Quote from: Doctor Gollum on 05 January 2023, 21:50:47
Its almost a 50mile each way trip to where I am going on Tuesday , but i know I will get sorted. at the moment no codes present. tho been in that situ twice before.
Is he replacing the sensor then?
raywilb
Quote from: Doctor Gollum on 06 January 2023, 18:01:48
if faulty it will be changed. the warnings have never appeared  whilst mobile & because of that i am not sure , I would have thought if the nox is kaput the warning would appear every time i started the car,
Quote from: raywilb on 06 January 2023, 19:27:39
No, every time the crappy designed Conti NOx ECU gets a soaking.
Needs changing, or your trip will be a wasted one  :y
