Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: sat navs  (Read 20922 times)
    • E250 Est / Elroq
Re: sat navs
« Reply #45 on: 10 January 2023, 09:33:27 »
looks extremely similar....but grab the versions at some point and Ill let you know what I know.
Re: sat navs
« Reply #46 on: 10 January 2023, 09:40:02 »
That one is at least 3.0.
The Alabama Mumsybus (Oct 2009 build) is the 2.5 and the older single unit type with an SD slot above the screen. rather than the split screen/interface.
Re: sat navs
« Reply #47 on: 10 January 2023, 09:59:34 »
Thanks.
I was reminded when SWMBO came down that it was due in for a service today so I took it down & forgot all about sat-nav versions  :-[ .... I'll have a look later when I collect it  :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: sat navs
« Reply #48 on: 10 January 2023, 11:59:05 »
Never used a sat nav in my life. Now, where the fark am i?  :D
Re: sat navs
« Reply #49 on: 10 January 2023, 17:04:21 »
2017/18 (V16.0) EUROPE  :y
    • E250 Est / Elroq
Re: sat navs
« Reply #50 on: 11 January 2023, 07:59:26 »
Can you grab the hardware details too, looking for something like NTG 4.5 etc
Re: sat navs
« Reply #51 on: 11 January 2023, 08:31:27 »
Where do I find that?  :-[
    • E250 Est / Elroq
Re: sat navs
« Reply #52 on: 11 January 2023, 10:20:22 »
Some show on the menus, just discovered mine doesnt!
google found this doc, prob the easiest https://incartec.blob.core.windows.net/instructions/Mercedes%20NTG%20Head%20Unit%20Differences.pdf
Re: sat navs
« Reply #53 on: 11 January 2023, 10:32:03 »
Thanks for that Jim  .... I'd looked almost everywhere for something like that.
Looks like I have the  APS NTG 4.5 (2012-2015)  :y
    • E250 Est / Elroq
Re: sat navs
« Reply #54 on: 11 January 2023, 10:48:06 »
In that case, same as mine....process is easy
Essentially you get a map update USB of your current map....But removing the map files
and a 2nd USB of the new map update.
You put in the first USB stick....It says this is the same as youve got, do you want to reinstall, you say yes and it immediately fails as theres no map on the stick.. so it says retry...
You now put the 2nd stick with the new files in, and off it goes happily carrying on without needing a PIN.
sometimes fails a couple of times while applying, but carrys on from where it left off until complete.
No guarantees obviously, but ive done it 3-4 times no problem.
Ill let you know where the files are to put on a USB stick (32 GB, formatted as fat32) if you want to have a go?
Re: sat navs
« Reply #55 on: 11 January 2023, 12:20:10 »
using the USB socket in the arm rest?  :-\
There's a SD card slot in the front.
    • E250 Est / Elroq
Re: sat navs
« Reply #56 on: 11 January 2023, 12:48:50 »
Yes,
The hidden USB, that SD is for holding your settings, music etc iirc
Re: sat navs
« Reply #57 on: 11 January 2023, 17:51:25 »
Yes,
The SD card is where I keep my 'Wheels on the Bus' sing-along music!  ;D
Re: sat navs
« Reply #58 on: 11 January 2023, 17:52:25 »
In that case, same as mine....process is easy ...
I foresee a trip to Flintshire ....  ::) ::)
Mister Rog
  • Wales
    • Volvo XC70 & V70 D3
Re: sat navs
« Reply #59 on: 11 January 2023, 18:18:37 »
Does all of this mean that my AA handbook won't work any more  . . .
“The desire to be a politician should bar you for life from ever becoming one.” Billy Connolly
Pages: 1 2 3 [4] 5 6   Go Up
