Coolant leak
Started by STEMO, 10 January 2023, 15:17:02
Smallish leak around the bottom of the radiator somewhere. Thought I might take it to the car doctor for a bit of TLC, but decided to give it a bottle of redweld medicine to see if it got better. We'll see  ;D
Diesel till I die
OMG you can't admit to doing things like that on here!  :o
Quote from: Sir Tigger KC on 10 January 2023, 15:53:28
I've been using it since before most of the pups on here could drive. Does the trick with small leaks.
Diesel till I die
cam.in.head
yes radweld and barrs etc work fine .especially if you only use a small amount.
i always add a half bottle when doing a flush and refil to all my cars . heaters all still work fine. ( obviously excessive amounts will settle and clog a matrix but quarter ir half bottle dont !
Quote from: cam.in.head on 10 January 2023, 17:40:54
Whole bottle went in mine. It was raining, you know  ;D
Diesel till I die
cam.in.head
itl be fine !
i once had a xj6 that sprang a rather large leak from thefront somewhere .(big pool under after shopping trip). put a bottle of barrs in and filled it back up. it never leaked again and was fine 2 years later when i sold it
Quote from: cam.in.head on 10 January 2023, 17:48:41
itl be fine !
I've always used the whole bottle, because it says use the whole bottle  ;D
Diesel till I die
Quote from: STEMO on 10 January 2023, 17:23:47
In that case I'm surprised that you didn't crack couple of eggs in there if you're that old skool!  ;D
Quote from: Sir Tigger KC on 10 January 2023, 17:54:43
Done that before, once. It didn't work.
Diesel till I die
ronnyd
Quote from: STEMO on 10 January 2023, 18:28:25
Did you have a nice breakfast though?  :)
Quote from: ronnyd on 10 January 2023, 18:57:20
No, Ron, you don't put them in with the shells on.  ;D
Diesel till I die
Did you use free range or battery hens eggs?  ???   :)
Quote from: Sir Tigger KC on 10 January 2023, 19:07:47
Proper, fossil fuel hens, not poxy electric ones.  ;D
Diesel till I die
ronnyd
Quote from: STEMO on 10 January 2023, 18:58:36
Silly clucker.  :P
countrywoman
So no sheep poo then? Told  by a few folks it works.
