Author Topic: Coolant leak  (Read 3931 times)
    • Astra 1.6 diesel
Coolant leak
« on: 10 January 2023, 15:17:02 »
Smallish leak around the bottom of the radiator somewhere. Thought I might take it to the car doctor for a bit of TLC, but decided to give it a bottle of redweld medicine to see if it got better. We'll see  ;D
Diesel till I die
    • Ford Mondeo 2.2TDCi TitX
Re: Coolant leak
« Reply #1 on: 10 January 2023, 15:53:28 »
OMG you can't admit to doing things like that on here!  :o
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #2 on: 10 January 2023, 17:23:47 »
I've been using it since before most of the pups on here could drive. Does the trick with small leaks.
Diesel till I die
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Coolant leak
« Reply #3 on: 10 January 2023, 17:40:54 »
yes radweld and barrs etc work fine .especially if you only use a small amount.
i always add a half bottle when doing a flush and refil to all my cars . heaters all still work fine. ( obviously excessive amounts will settle and clog a matrix but quarter ir half bottle dont !
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #4 on: 10 January 2023, 17:45:04 »
Whole bottle went in mine. It was raining, you know  ;D
Diesel till I die
cam.in.head
  • West yorkshire
Re: Coolant leak
« Reply #5 on: 10 January 2023, 17:48:41 »
itl be fine !
i once had a xj6 that sprang a rather large leak from thefront somewhere .(big pool under after shopping trip). put a bottle of barrs in and filled it back up. it never leaked again and was fine 2 years later when i sold it
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #6 on: 10 January 2023, 17:50:47 »
itl be fine !
I've always used the whole bottle, because it says use the whole bottle  ;D
Diesel till I die
Re: Coolant leak
« Reply #7 on: 10 January 2023, 17:54:43 »
In that case I'm surprised that you didn't crack couple of eggs in there if you're that old skool!  ;D
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #8 on: 10 January 2023, 18:28:25 »
Done that before, once. It didn't work.
Diesel till I die
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Coolant leak
« Reply #9 on: 10 January 2023, 18:57:20 »
Did you have a nice breakfast though?  :)
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #10 on: 10 January 2023, 18:58:36 »
No, Ron, you don't put them in with the shells on.  ;D
Diesel till I die
Re: Coolant leak
« Reply #11 on: 10 January 2023, 19:07:47 »
Did you use free range or battery hens eggs?  ???   :)
    • Astra 1.6 diesel
Re: Coolant leak
« Reply #12 on: 10 January 2023, 19:08:45 »
Proper, fossil fuel hens, not poxy electric ones.  ;D
Diesel till I die
ronnyd
Re: Coolant leak
« Reply #13 on: 10 January 2023, 19:20:34 »
Silly clucker.  :P
countrywoman
  • worcestershire
    • skoda yeti
Re: Coolant leak
« Reply #14 on: 10 January 2023, 19:28:45 »
So no sheep poo then? Told  by a few folks it works.
