No washer bottle water.
Started by Field Marshal Dr. Opti, 27 January 2023, 18:31:48
Washer bottle full and I can hear the pump working but no washer water.
Cleaned the washer jets but still nothing wet at front and rear.
Washer pump filter? ( if there is one).....fuse?....which I doubt as I can hear the pump trying to work.
cam.in.head
if were talking omega then the pump filter rubber bobbin is the usual culprit but you said rear too ?
different car (or estate !)
Quote from: cam.in.head on 27 January 2023, 18:43:20
I think the washer bottle pump on the Signum serves both front and back  screens.
GastronomicKleptomaniac
Definitely worth prodding the wee filter thing
Mmm if it's anything like my Mundano, the washer bottle and pump is hidden way up behind the front bumper....  ::)
ronnyd
Quote from: Field Marshal Dr. Opti on 27 January 2023, 18:57:49
Does on my humble Vectra, so you are probably right.
Quote from: Sir Tigger KC on 27 January 2023, 19:00:51
Behind the passenger side wheel arch  I believe. Which sounds like easy access except all the screws are well shagged making a relatively simple operation anything but......
Quote from: ronnyd on 27 January 2023, 19:02:14
There is absolutely no relationship between the humble common as muck Vectra, and the majestic, rare, and highly desirable Signum, Ronny. ::) ::) :)
dave the builder
Could be the rubber bung filter clogged
some of these "front and rear" pumps have a valve in that sticks.
the BCM selects front OR rear by reversing polarity on the motor .
Pop out the battery and you might be able to dig down to it from above. The filler neck is also removable to create some space ;)
Maybe M'Lud's new battery has fried the pump!  :)
dave the builder
Quote from: Sir Tigger KC on 27 January 2023, 21:25:08
Maybe M'Lud's PUT THE new battery ON THE WRONG WAY ROUND ADAIN has fried the pump BCM !  :)
fixed  ;)
ronnyd
Quote from: Field Marshal Dr. Opti on 27 January 2023, 19:08:55
Oh dear, the delusional upper classes.  :P  ;D
dave the builder
Quote from: ronnyd on 27 January 2023, 22:13:15
Signum review (Retired Police Interceptor) clicky   ;D
Quote from: dave the builder on 27 January 2023, 22:38:06
Oh dear  ;D
Diesel till I die
