Fancy something a wee bit different?
Started by STEMO, 02 March 2023, 14:57:46
Diesel till I die
ronnyd
Will they do an electric version?  :D
Spitfire lump.....and I don't mean the nancy boy two seater by Triumph.
YZ250
I remember The Beast being on display at Milton Keynes shopping centre many many years ago. It had the Rolls Royce grill on it then.
Quote from: Field Marshal Dr. Opti on 02 March 2023, 17:44:50
It's a Meteor out of a tank, not a Merlin. They're much easier to adapt to car use, lacking the gearbox for the propeller and drive from the 'right' end.
The car is particularly impressive as it whines, rattles and smokes past you on the motorway :y
Quote from: Nick W on 03 March 2023, 08:10:49
The original tank engine was destroyed in a fire, it now has a Merlin V12
Diesel till I die
YZ250
It started life with a Meteor engine but after an engine fire it was changed to a Merlin. It definitely had a Merlin in it when it was displayed at Milton Keynes.  :y
I thought the Meteor and Spitfire shared the same lump apart from the Spitfire being Supercharged and the Meteor being NA.
I could well be wrong though.
Quote from: Field Marshal Dr. Opti on 03 March 2023, 18:52:31
That was the main difference. I think they used up "B" grade parts not suitable for aviation use and bits recovered from crashed aircraft since the engine was subject to much less abuse in a tank (and had half the power anyway since the supercharger was deleted).
countrywoman
V12, just stick 2 Omega v6s together!!!
Quote from: countrywoman on 03 March 2023, 19:54:29
If it's good enough for the Mundeo Coupe :D
