in tank fuel filter bobbin .carlton,senator ?
Started by cam.in.head, 28 March 2023, 19:02:40
cam.in.head
hi all.
im looking for the plastic round bobbin prefilter that sits on the end of the fuel pickup pipe .its for a carlton but im sure a similar unit would be found on similar gm cars of the era. possibly senator,manta,monza ,astra maybee ?
just pushes onto the end of the 12mm od pipe.
Would something like THIS be suitable? That's one of the first results Googling fuel tank filter sock, you might find exactly what you want spending a bit more time looking at the rest :y
cam.in.head
thanks for reply.
mine is a plastic round bobbin that sits in the swirl pot .the sock would probably be more for carburretted cars where the pick up lays on the bottom.   obviously a big enough sock if i could find one would fit around the plastic !   chreers
dave the builder
I've never seen a swirl pot on a carlton tank/pump  ???
saloon the pump was mounted on the side of the tank , estate the pump was in-line  :-\
cam.in.head
the carlton tanks have the swirl bowl built in to the tank base. the pick up and  return pipes all feed from / into it.   external pump ,damper and filter mounted inline.
i may  have found some finemesh sheet which i can wrap around the bobbin unlesssomething better popsup !
cam.in.head
think im sorted. another forum member mentioned spray gun paint filter .never would have thought of that..have ordered one of those and a sheet/piece of fine brass filter mesh too !
