ncdc2013
Started by john1959, 27 April 2023, 22:55:01
john1959
just tried replacement ncdc2013 bose as original one knackered.put it in it works great but comes up on screen display safe.dont know what that means ,got the paired screen aswell but  no code,any idea on the way forward?cheers
Safe means it's missing the code.
If they're a matched pair the entering the code should make it work.
If they're not, then you have a really bulky coaster.
Assuming you dont have a tech2 to hand, and the pairing codes for both the original and replacement, the Headunit (with CD Changer), Screen and Telematics (on 2015) need to be kept together, as they are all security paired to each other.
And no code to enter on any component.  The pairing code can only be entered or removed by a tech2 or similar device.
john1959
thanx,i have the code for original but no sound as its kaput thats why i got another ncdc 2013 with screen .head works great but need to change the screen to have them together.dont know how to change screen.then no code for the new pair as they are paired and its colour screen.maybe im going nowhere without the code.
If the replacement head unit and screen are paired already then it should just work.
Unless you've locked out the new head unit by connecting it to a different screen.
john1959
i took old head out 1st and put new head in didnt change the screen as i dont know how head worked like new after 3or 4 mins screen showed display safe thats it.but great sound
Start at the beginning.
So it originally had an NCDC2013 and what type of screen? Both paired together?
The replacement is an NCDC2013 and a CID, which are paired together?
If yours had a GID (see Display Types in Info sections of forum), then you need to check if you have the CID cable tucked up behind the screen area of dash - usually wrapped in masking tape, but not all have the CID cabling.  If you don't have the CID cabling, it's not hard to fit, but I'm reading between the lines that it may be a struggle for you?  The CID will work without it, but you won't be able to use the map display of the sat nav.
There is a guide how to get the dash out to change the screen.
Option 2, if yous has no sound, swap the lower rear board of the top unit over inside the NCDC.  That board is not coded, so can be swapped at will.  I get a feeling I wrote a guide, but that might have been NCDC CD Charnger board ;D
Quote from: TheBoy on 28 April 2023, 19:16:40
I think I wrote that one....  ;) ;D
Quote from: VXL V6 on 28 April 2023, 19:30:48
Ah, possibly ;D.  I know I've seen one ;D, And as you and I are probably the ones with the most in depth knowledge of the NCDC system, it would likely be one of us!
john1959
new ncdc13  and screen colour! sucessfully fitted backs killing me.just need to know where to get the little screws from to secure the head.yes the boy i found the the colour socket behind the dash taped up and fitted it thankyou all for your help. ;D ;D :y
The little grub screws you put in where the extraction keys go?  They are purely aesthetic.  If you want them, they are bog standard grub screws with an allen head, available from just about anywhere.  Not sure of size, as don't have one to measure.
Glad you sorted the issue though :y
Migv6 le Frog Fan
I must have a go at sorting mine out at some point. Several problems have popped up over the last year. CD changer cartridge is stuck and wont come out.
Radio seems to like going to LBC despite me selecting a different station, and sometimes selects NAV when I selected another option.
Could put the original with mono screen back in, but I like the colour screen.
Sourcing another one might actually be the best option I suppose.
Quote from: Migv6 le Frog Fan on 03 May 2023, 13:36:37
Does the NCDC2013 paired to the GID work? Easy enough to repair the NCDC2013 paired with the CID if it does.
Migv6 le Frog Fan
It worked fine when I took it out of the car about 6 years ago. Stored in a nice dry place ever since, so hopefully still ok.  :y
