Author Topic: Rear Wheel Bearing replacement - Wirral/North West. Any advice ?  (Read 6571 times)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Hi,
I suspect rear O/S wheel bearing is grumbling.  Above 20 mph get a grumble, and goes if take a right hand corner.
They have never been done so probably time they were changed.
Car is a 2.5V6 manual, V Plate Mini Facelift, SALOON.
I have had look at the guide and I think best somebody who has done a few and has the right tools best I think.
Any advice or recommendations as to whom could assist in Wirral/North West ??
I would change and put new rear Discs on as well, and new handbrake shoes.
Any recommendation as to decent bearing ?  I believe Saloon has different size ????  Want to make sure I get the right one :)
Thanks in advance.
Andy.
SKF should be a safe bet.
If you get a choice of two sizes, go smaller. The estate/Monaro ones are a smidge wider, 2mm iirc  ;)
Starter for 10...
https://www.ebay.co.uk/itm/334801495817
Trusted supplier that I have used repeatedly  :y
An example of the wrong size...
https://www.ebay.co.uk/itm/124169843200 ;)
DrAndyB
Starter for 10...
Many thanks  :y  Ordered 2 from SKF directly just now.
Just need to find somebody to fit them for me :(  #Pleasehelp
relluf
Hi Andy
If it's any help I had a rear bearing replaced on my elite by Buckley tyres (in Buckley obvs)
The guy there,Kev I think had done a couple before and took it on for me as no one else seemed willing.
I can't just remember the costs but will try to resurrect the thread  to give you an idea.
HTH.
« Last Edit: 14 May 2023, 22:19:43 by Franks Dad »
    • E250 Est / Elroq
Hi Andy
HTH.
I Think I put you onto Buckley Tyres.....
However, like many other places they have been bought out by Pro Tyre (same outfit that bought Blackboots / Wheels in motion) now.....  That geometry bay gets you out as fast as they can now with an 'In the green'  They are not what they once were....
DrAndyB
I don't mind doing it myself as pretty confident and handy with the spanners, and looks not too bad but I don't have all the right tools at present as would need
  • Suitable bearing puller / contraption
  • Suitable bearing putter back inner
  • Suitable Hub puller and putter back inner
  • Suitable impact wrench for the big nut
  • Correct size sockets for hub bolt and driveshaft bolts
I think thats it.
There is a place called "AutoVaux" on the wirral I may consider but not sure if anybody has used them or known to have done Omega Bearings before.
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
I've done several of these. It's a 90 minute job, working in the street. I would be very unhappy to pay a garage more than an hour to do it.
LINK for the bearing puller/installer. That's a recommendation for the tool and not the supplier, which was the first one in the search. It's a very useful set.
30 or 32mm(I don't remember which) deep socket for the hub nut. Both are common sizes for hubs and driveshafts
6 or 8mm allen socket for the driveshaft bolts. Hardly special when most  large bit sets include them.
Impact wrench - you'll need a serious tool costing several hundred quid to even get close. A £50 700mm long breaker bar will do it easily. A long-handled 1/2" ratchet for winding the bearing out/in. Together those are the same as a bare cordless impact that might handle wheel nuts.
I made a hub extractor as I don't like beating on such things, especially when access is so poor. It's not complicated, and there are other ways of doing the job.
Or, you could remove the semi-trailing arm and pay your local garage to use their large press to remove and refit the hub and bearing. I reckon that's just as awkward as removing the bearing on the car, so don't do it.
