At the doctors today
Started by redelitev6, 28 June 2023, 18:36:03
redelitev6
 :o Rubber glove and lube involved  :o
If that's how you get your kicks ;D
Seriously, hope its all OK.
Ugh...  :(
Hope the outcome was good.  :)
Migv6 le Frog Fan
A bit embarrassing if you got a stiffy during the examination.  :o ;D ;D
ronnyd
Quote from: Migv6 le Frog Fan on 28 June 2023, 19:40:32
Would have thought that was the last thing on his mind.  ;)  Hope all is ok.  :y
Even more embarrassing if the stiffy was up your arse  ;D
Diesel till I die
redelitev6
Doc said all was good , just waiting for blood and pee test results , turns out I have a low Iron count and they don't know why
Varche
How does the UK system for getting the urine sample work?
Here we get given a cylinder ( plastic of course) . You put your sample in it and screw the lid on. Then you the punter, press a tube in the top and as the tube has a vaccum which in effect sucks a specimen in and then seals. The nurse then just sticks a label on the tube with your details on. Nurse takes your blood sample. Results of both are available in a week with two pages of detail highlighting anything out of limit.
Hope they get to the "bottom" of your problem
PS First thing Spanish doctor asks when you go in is " Are you walking?". Everyone is expected to walk every day! ( easier when it doesnt pee down every day)
I thought the lubed finger was given to all men over 50 as standard NHS procedure.
Quote from: redelitev6 on 28 June 2023, 21:05:28
Hemo or ferritin?
Quote from: Field Marshal Dr. Opti on 29 June 2023, 11:21:39
Can't say I've ever had a man's finger up mine...
Quote from: TheBoy on 29 June 2023, 14:07:54
I had a Colo-rectal surgeon who was 6ft+, built like a brick shithouse and had hands like spades who examined me a few times!  :o
He'd give me a little pat on the bottom when he'd finished, cheerfully saying There you go, all done!   ;D
Migv6 le Frog Fan
From what weve heard about yours, the Doc would take one look and run a mile.  ;D
Quote from: Sir Tigger KC on 29 June 2023, 14:31:32
[/i]  ;D
Did he offer a reacharound? ::)
I believe women also carry out the procedure......any better? ;)
