I've been given this for free.
Started by Field Marshal Dr. Opti, 13 July 2023, 16:50:10
A few years old and taken off a BMW M340i ( before being sold) with the same B58 lump as my car. About £230 new and anywhere from £50-£150 used on ebay.
Very simple to intall ( about 2 minutes) and works on the MAP sensor only. Very safe, I'm told.
Anyone have experience of this type of thing?
If it only plugs into MAP, I assume it fools the ECU into thinking the boost is lower than it is, and allowing more boost from the turbos....
Bit of a bodge IMHO, potentially harmful to car....
Diesel till I die
I had something like that on my old 530d which pulled and sounded like a Deltic locomotive!  :y
I never tinkered with it so I don't know if it made any difference.  :-\
Quote from: TheBoy on 13 July 2023, 16:59:17
Exactly. It has a switch inside that can add  up to an extra 4.5PSI of boost.
It's a pretty mild device so very unlikely to harm the engine. Most cars come with restricted boost from the factory these days. I believe the 3 pot 1000 cc Fiesta engine is available with 3 different power outputs, obtained  by playing with the boost pressure.
Quote from: Sir Tigger KC on 13 July 2023, 17:22:37
Yes...I remember you saying that
Turbo derv motors respond well to a bit of boost tweaking. >:D
Raeturbo
Boost boost and boost some more and be merry😁🔥
Laying a rubber road.
Quote from: Raeturbo on 13 July 2023, 18:10:09
I imagine your Evo is bursting with boost..... :D ;)
Raeturbo
It has burst a couple of times in the past ;D ;D but I'm running a nice safe 1.8 bar at the moment 🤣
Quote from: Raeturbo on 13 July 2023, 18:33:42
How much is this in old money? 8) >:D
YZ250
Just be aware that BMW's store boost data, amongst many other things. Bear in mind that all of the stored data is available to show if the vehicle has been working outside of its parameters, even during a normal service.
Being so new, I'd hate for you to void your warranty.  :y
dave the builder
Quote from: Field Marshal Dr. Opti on 13 July 2023, 18:38:37
26 PSI
My Omegas GM branded tyre inflator is in BAR not PSI   ::)
so I drag out the 2HP compressor because u can never remember how many BARs i need per tyre  ;D
Quote from: YZ250 on 13 July 2023, 19:35:05
^ This.  Any modification including rolling road sessions are recorded.
the map would be storing the false value though.  that said, as it will impact other stuff, it would be noticeable if anyone looked hard enough...
Agreed.
I imagine that even if the device is removed prior to a service there is 'stored data' available to BMW if the 'data police' from 1984 want to dig deep enough. Although, I doubt there would be a problem with the warranty if the warranty claim was related to the central locking or electric seats not working properly.......or anything unrelated to boost pressure.
It's a pretty quick car as it is ( sub 4 seconds to 60 MPH) according to Dragy so I'll probably keep my powder dry for now. :y
