Z16XER oil leak
Started by Viral_Jim, 15 July 2023, 20:57:29
Viral_Jim
One of the advisories on today's MOT was for a not serious oil leak down the back of the block. Apparently it wasn't dripping but the block is wet so it's definitely current.
Before I go flailing about, torch in hand, are there any likely suspects I should be checking out first?
I've all but ruled out the rocker cover gasket, I wasn't in working gear  but I had a quick look and the very top of the block looks dry, plus the gaskets were replaced only 2yrs /18,000 miles ago.
Any suggestions welcome  :y
Viral_Jim
Not sure how these would give you an oil leak... I thought they were vacuum operated?  ???
Will have to get the book out ;D
Quote from: Viral_Jim on 16 July 2023, 08:59:49
The operating mechanism is external, whilst the flaps are internal.
Worth a look around the oil cooler area and I seem to remember a field remedy for the cam bearing bridge sealant, give the area a good wash down and then look.
Apologies, for some unfathomable reason I thought it was a diseasal :-[
Viral_Jim
Thanks both, I will investigate further.
Mark: oil cooler is good, since I did all the seals just over a year ago. Cam bearing bridge I will have to do some googling I think
