Front or Back?
Started by Sir Tigger KC, 08 August 2023, 13:32:03
I've got a pair of new tyres on the Monsit and I generally put new tyres on the front for better traction and water displacement in the wet.
However, I've see some say that new tyres should go on the back to increase traction on the back end reduce the chance of the back end sliding out.
What do you lot do?  ???
Rangie
Had two new tyres on my V8 Merc when I had it a couple of years back, and was advised by the fitter to put the new ones on the rear but in all honesty  I never noticed any difference. With my 4x4s I always replace all 4 at the same time.
dave the builder
The fronts do the steering, most of the braking and on Wrong wheel drive ....the traction
rears just get dragged about on WWR ,unless things go wrong  :P
It's wwd. The rear wheels just stop the back end from being dragged down the road. ;)
If you're worried about lift off over steer, the don't drive like a twart or buy a proper car >:D
if you go to Costco you won't get a choice ... they will put them on the rear (assuming same size front & back)
Raeturbo
Rear.... The front is a  lot easier to control than the rear in the event of an emergency.
Laying a rubber road.
Quote from: Andy B on 08 August 2023, 14:19:26
I'd get a choice. "Fit them to the front or shove them up your arse"
Diesel till I die
Quote from: Raeturbo on 08 August 2023, 16:11:47
That depends on the circumstances, car and driver.
Best tyres should be on the rear, as most people can deal with understeer or front end lock-ups, less people nowadays can cope with oversteer.  More so with cheap budgets, where the dry v wet grip is so dramatically different, and can catch people unawares.
I usually put the best on the rears if the car setup allows, even with the decent tyres I choose.
Raeturbo
Exactly, and well known by good drivers for years👍
Auto Addict
Quote from: TheBoy on 08 August 2023, 17:24:39
I don't have a problem with oversteer/understeer as I never go over 35mph, and 5mph around corners.
I like red cars
Varche
That must be mostly motorway driving AutoAddict!
Auto Addict
Quote from: Varche on 09 August 2023, 09:06:03
Centre Lane job.
I like red cars
Varche
The real reason they recommend putting the new ones on the back for FWD is because the rears wear pretty slowly and can be a fair old age, this means you keep the tyre age down.
