Still wont start.
Started by Duke01, 20 August 2023, 14:00:22
Duke01
So after replacing the starter, and it started fine,
I had a fault code of PO758, shift solenoid
Cleared code and she ran fine. Then the shifter starting acting up, all lights lit up and went in to limp mode.
Now the car wont start at all! as in wont crank, again, So back to square one.
Any ideas?
You need to follow the selector plate repair guide.
Yup, sort out the range switch (aka selector switch)
biggriffin
A bit of searching in the handy named maintenance section turns this up
https://www.omegaowners.com/forum/index.php?topic=90673.0
Hoof'land storeman.
