Heater Fan
Started by Omega Nige, 06 September 2023, 12:39:05
Omega Nige
Hi, I just put my Omega in for an MOT, which it passed :) They turned off the heater fan for the MOT, when I switched it back on to drive home there was  a big vibration which sounded like I had plane inside! I do not seem to have any play on the fan so something else is vibrating. Any ideas?
Thanks, Nigel.
Sunroof ajar with the windows closed :-\
Some cars buffet really badly inside unless a window or two is open as well.
Omega Nige
Air-con working fine so nothing open ;D I can feel the vibration if I put my hand on the fan motor. Glove box already out.
Best pull the fan out then ;D
Fan vibration was not the noise you described, hence the reply.
Omega Nige
 Fan removed, found a mushed up card in the fan, dont know how it got in there ;D Now I just need to put everything back :)
biggriffin
Found a mushed up card?? I would have a check of the pollen filter,,and ensure it's okay.
Hoof'land storeman.
