Sunroof motor assembly change
Started by tooleater, 09 September 2023, 15:39:55
tooleater
Is it doable, went through maintenance guides, did I miss it or is it not on there.. Have complete assembly ready to go, but not today guys, its too bloody hot  :-\ Oh its a 3.2 Elite
Migv6 le Frog Fan
Its been a few years, but I think its just held in place by three or four screws. Not too difficult.
Are you sure that the motor is faulty? In general, they're pretty reliable.
The rest of the mechanism is prone to rust, seizing and other damage. This is true for all sunroofs, not just Omegas.
tooleater
That's a very good point buddy about corrosion and seizure. The last car which I accidently rearranged didn't have a sunroof, so it makes sense that constantly exposed to the elements the poor thing probably has had a hard life. I might just leave it, but last owner removed relay as he said it had a habit of trying to open of its own accord. That definitely as you suggest is pointing to some sort of seizing.
Thank you  :y
dave the builder
Quote from: tooleater on 09 September 2023, 20:19:33
Thank you  :y
sounds like the control dial to operate the roof is the problem from your last post .
I think there's a guide on cleaning the tracks of the switch  ;)
tooleater
Thanks for that Dave, I will replace the module and drive motor as I have a new one, came with the car and I'm assuming once I remove the complete unit, that I would be able to turn the female side of the worm drive gear to prove the mechanical part gubbins of the sunroof is not seized. Or hoping that's the case...
Cheers  :y
Don't force it manually like that. It will never be where it thinks it is causing more issues as the position sensors are all in the motor housing.
Interior light out and two screws. Trim off. Motor bolts and plug and refit.
Emergency operation is by way of the Allen key in the tool bag as per owners manual.
tooleater
Thankyou for that buddy, you just saved me from taking the wrong plan of action. I was just sitting in the car having look and thinking I bet there are screws behind that interior light  :y
Quote from: tooleater on 16 September 2023, 13:52:03
And the control knob from memory. Haynes is accurate for much of the trim in addition to the pretty comprehensive guides here :y
