Time for a new mower?
Started by Viral_Jim, 09 October 2023, 09:17:12
YZ250
Quote from: TheBoy on 10 October 2023, 09:06:46
And we have a secret B&S saddo on the site, isn't that right Mr YZ250 ;D
;D ;D
This only came about when Mrs YZ got herself an allotment a few years back (given it up now). I have no interest in growing stuff and my knowledge of such things is zero, but because I'm a thoughtful hubby I mowed the large plot that she had for her. On one occasion the mower started playing up, so I stripped it apart, whacked a carb kit on it for less than a tenner and away it went.  :y  The chap on the next plot had seen me working on it and asked if I'd look at his broken Hayter Harrier, so I fixed that. Somehow word spread that I was the Go To man for fixing/servicing mowers, rotavators, strimmers, chainsaws and hedge trimmers. I had them lined up in my garage. It then progressed to servicing/repairing the school ride on mower, the Toro general mower and the cricket pitch cylinder mower. I eventually had to call a stop to it.  ;D
Atco have been around for a million years so you should be ok with it.  :y
I have a Qualcast petrol mower and it is utter shit.
Won't pull the skin off a race pudding. Add in flimsy build quality and a  plastic carb. I may look at a used 'old school' ATCO type mower suggested by Mark DTM.
Viral_Jim
Quote from: YZ250 on 10 October 2023, 11:19:09
;D ;D
This only came about...
Ah don't be so modest, you sound like a well credentialled expert to me. You can expect my call shortly  ;)
;D ;D
when can I bring you my Atco?  ;D It'll run of a fashion ....  :-\
Quote from: Marks DTM Calib on 10 October 2023, 07:23:50
Quote from: Sir Tigger KC on 09 October 2023, 18:59:26
I recently bought a second hand Mac Allister (B&Q own brand) petrol lawnmower which has a 125cc Briggs and Stratton engine, after my trusty old Bosch Rotak electric mower fell apart.  :(
I've only used it once so far, but once I got going after faffing about filling it with petrol and getting it started, it mowed my lawn nicely and quicker with the wider deck.  :y
Much heavier than the leccy mower though, and as it's not self propelled, mowing the lawn will be good exercise in future!  :)
Hence the advice on the Atco, self propelled and the ES  model has electric start   :y
Yes this Mac Allister I have is pretty basic. No throttle or choke so runs at preset revs and has a little primer bulb to pump fuel into the carb. It retails new at about £230 so you get what you pay for I guess.
I'll see how I get on with it.  :)
Quote from: Viral_Jim on 10 October 2023, 09:52:34
Well, I suppose we'll find out, I've bought it now... ;D
I had a look and whole new carbs can be had for £20-35 depending on how authentic you want them to be, and service kits for half that amount. I figure less than £50 I should have a very usable mower.   :y
Good tip on the E5 Mr TB, I honestly wouldn't have thought of that. :).
Genuine carb refurb kits are around a tenner delivered.  Probably worth always having a spark plug and a clean air filter in stock - both should cost around £2-3 delivered each.  It'll most likely have a metal blade, so hop that off at use a grander to put a good edge back on it.  Change the oil (I use GM semi synth in mine, just because I had some).  Nothing else to do really.
I change the oil in mine every couple of years, if I remember, and the plug when it stops working, and might remember to check the air filter every 5 years...   ...just dont tell Al how much I abuse mine ;D
Quote from: Andy B on 10 October 2023, 13:34:46
;D ;D
Oi! There's a queue...
Quote from: TheBoy on 10 October 2023, 15:32:07
;D ;D
;D ;D
ronnyd
Quote from: TheBoy on 10 October 2023, 15:30:21
Is a grander a very posh grinder?  ;)
YZ250
;D ;D
;D ;D
See how the jobs can soon add up.  ;D
It's not called the neverending list for nowt ;D
Viral_Jim
I assume there's no oil filter on these? I had a look on B&S but as far as I can tell the only ones they sell are for tractor mowers.
YZ250
Quote from: Viral_Jim on 10 October 2023, 19:50:36
Not to my knowledge. I just lift all four wheels on to bricks and undo the square drive plug in the blade well to dump the oil.  :y
YZ250
It'll most likely have a metal blade, so hop that off at use a grinder to put a good edge back on it ..........
And remember to sharpen it equally both sides so that the blade doesn't go out of balance, otherwise you end up with a vibrating mower.  :y
Quote from: YZ250 on 10 October 2023, 20:39:00
Big Vera would be chasing you around the garden asking for a ride  ;D
Diesel till I die
