Time for a new mower?
Started by Viral_Jim, 09 October 2023, 09:17:12
Quote from: Sir Tigger KC on 15 October 2023, 13:31:28
Quote from: Field Marshal Dr. Opti on 15 October 2023, 12:53:13
Anyway.....I also need a new mower.
Must be petrol.
Not a 'girlie' electric or battery job.
51CM or 20 inch cut.
NOT QUALCAST CRAP
Not fitted with a made from wet cardboard B&S motor, regardless of what Tigger and TB think.
£200-£450. :)
I'll have a  look in B and Q this afternoon.
Lidl have Parkside petrol mowers at the moment. £129.99.  What could possibly go wrong?  :)
I doubt it has a 20 inch cut....but worth a look. :y
My grass cutter is 5 foot 2 inch tall , cute and blonde, and makes a grand cup of tea. ::) ::) :y
Quote from: Mr Skrunts on 15 October 2023, 13:53:07
You don't say if this individual a man or a woman? ::) ::) ::) ::) ;)
Quote from: Field Marshal Dr. Opti on 15 October 2023, 14:04:12
Or both?
Diesel till I die
She is my grass cutter , single and a good  kisser :-X tea maker.
Quote from: Mr Skrunts on 15 October 2023, 15:16:45
5 minutes ago the term 'she' was self-explanatory. These days there are plenty of 'she types' rocking the old meat and two veg.
Have you checked, Skruntie?.. ;) ::)
A Gentleman never tells it all.
Quote from: Mr Skrunts on 15 October 2023, 16:48:40
Do you know any gentlemen? Apart from, maybe, your grass cutter  :)
Diesel till I die
Quote from: STEMO on 15 October 2023, 18:24:38
Skruntie must be a wealthy man if he can afford a 'grass cutter'
I thought it was supposed to be grim up north. ::) ::) ;)
Quote from: Field Marshal Dr. Opti on 16 October 2023, 12:26:45
Life is simple, not grim. London is grim.
Diesel till I die
Quote from: STEMO on 16 October 2023, 13:10:37
With ethnic cleansing and bus fires are almost a weekly occurrence your not so far behind Lundun.
Oh wait, that's Bradford. An easy mistake to make.
Quote from: Doctor Gollum on 16 October 2023, 16:41:14
Wrong county, and a single bus fire. Easy.
Diesel till I die
Quote from: STEMO on 16 October 2023, 17:47:03
Again, apologies,... I had forgotten that West and South Yorkshire were different count(R)ies >:D
YZ250
Quote from: Field Marshal Dr. Opti on 15 October 2023, 12:45:44
Would a Honda lump prove more reliable and last longer?
£200-£450. :)
You'll need to throw another couple of hundred more than your maximum to get a Honda Izy 18" cut, or another grand more than your maximum for the Honda HRX series 20" cut, or another twelve hundred for a Toro (Kawasaki engine). Some of the bigger cut Toro's are over two and a half grand.  :o
Now can you see why B & S are so popular.  ;D
I've mentioned on here before that I had a Honda Izy sat under my bench for around four years. The petrol had long since evaporated so I put some fresh petrol in it. It started first pull.  :y  I believe TB had one but mistreated it by subjecting it to volcanic temperatures and melting it.  ::)  ;D  The decks eventually rot out on the earlier Izy though.
Quote from: YZ250 on 16 October 2023, 18:35:50
£200-£450. :)
My Qualcast finally wet tits up today. Clouds of white smoke before finally deciding to seize solid. It lasted 6 years  but never seemed to have the torque to cut grass more than an  inch or two long. Good riddance to the pile of shit. ;D
Anyway, for now, I've decided to take a risk on just about the cheapest 53CM/ 21inch SP mower available. It comes with a 2 year warranty. If it lasts that long I'll be happy. Not sure about the engine other than being a 173cc 4 stroke lump ......probably from the land of the slitty eye.
Perhaps I'll be pleasantly surprised.
https://www.parkerbrand.co.uk/petrol-lawnmower-21-inch
