Multi Tool - Advice
Started by Mr Skrunts, 24 October 2023, 19:10:46
Never used one - Dont know anyone that has one. :-\
Picked this one  at random as an example.
https://www.screwfix.com/p/erbauer-emt300-qc-300w-electric-multi-tool-kit-230-240v/804pp
Are they worth it?
Gearbox speed - does the higher speed perform better?
Mains v cordless.
Attachments - Which brand fairs better for reliability/durability.
T.I.A. :y
Borrowed one. Bit shit. Never felt the need to buy one over tools more capable of doing the same thing.
YZ250
I've used and abused my Bosch PMF190E for quite a few years. It has its uses like any other tool, cutting through plastic pipe where a hacksaw won't fit, trimming wood where access with a saw is otherwise impossible etc.  I've never used it as a sander though as the small footprint of sandpaper would quickly clog up in my view.
I've never bought any new blades for mine, I just use a square file to file new teeth on the blades.  ;D  If you hit a nail or metal it blunts the blade quickly.
Allenm
I have the one you linked, it is good enough for most things that they do.
Had a bosch mains one before, and the cordless is just as good.
I have a Parkside mains multitool from Lidl, and it's fine for occasional DIY use.  :y
I have been looking at the Ryobi range, they have one with a pivoting head, considering that as I allready have batterys and a charger of thiers.
Just keeping an eye open for one on offer.  £130 @ Ryobi, £99 on Amazon at the moment.  No rush though.
I was looking for the kit I think they used to sell.  Storage/workbench where the base  utilises all the tools, not sure if it was any good, but would be ideal for the little hobby jobs. :y
Viral_Jim
I find mine really useful when a) access is tight or b) using it in a room that's already decorated due to the comparatively low levels of dust they produce.
I have a Makita one, but only because I already had the batteries. The only negative thing I have to say about them is the noise they make. Won't make you popular with anyone else in the house!
YZ250
Quote from: Viral_Jim on 26 October 2023, 10:07:28
I used mine today to do an undercut on a piece of wood trim. I was outside and it was still noisy. Definitely an ear defender job.  :y  I really must buy some new blades, instead of filing new teeth on them.  ::)
Quote from: YZ250 on 26 October 2023, 21:48:07
Too late, you've already buggered your hearing at the factory!
YZ250
Quote from: TheBoy on 27 October 2023, 08:20:14
;D :y
I wear hearing aids now but when I put ear defenders on when using the chainsaw/circular saw etc. it causes the hearing aids to whistle, so I have to remove the hearing aids and go back to being deaf.  ;D
Quote from: YZ250 on 27 October 2023, 09:43:11...., so I have to remove the hearing aids and go back to being deaf.  ;D
PARDON!  ;) ;)
sorry  ::) ... had to be done  ;D
YZ250
Quote from: Andy B on 27 October 2023, 20:34:28
PARDON!  ;) ;)
;D
I'm getting forgetful as well. I bought a new Mikita 4" Angle Grinder the other day as my my 9" was too big  ::) for the job I was doing. When I'd finished using it I put it on my tool shelf in the garage ......... next to the new, unused Mikita 4" Angle Grinder that I'd bought six months ago.  :-[  Still, my son will be happy as he might as well have one of them.  :)
Quote from: YZ250 on 28 October 2023, 21:13:17
PARDON!  ;) ;)
;D
It must be an age thing.  My 9" is dual speed ::)
No idea where it is either, It's a 2 speed Sealey from the days when I was valleting cars.   :y
PARDON!  ;) ;)
;D
At least yours was six months apart. On Thursday morning I decided I fancied a bacon and egg buttie for my lunch. I knew I had bacon so I called in the coop on my way home and bought six eggs. Life happened and I didn't get to have the bacon and egg buttie. On Friday I thought I'd have the bacon and egg buttie I didn't have on Thursday so, on the way home I called into the coop.................. ;D ;D
Diesel till I die
Talking tools  I have been having a big sort out, it's amazing the things that we buy/collect/forget about.
I bought the Multi tool, assembled it and had a go with it today, only tried the various speeds on some large pieces of cardbord that needed resizing for the bin.  As mentioned before I need to aquire some ear plugs and might as well het a dust mask in the process. :y
But found a Worx 4" saw that I bought to modifty a TV cabinet.
Small Delta sander.
Mini Dremel type grinder tool kit.
Soldering Iron/Station
Glue gun
Electric stapler/nail gun.
The intentions are good ::)
The list of stuff to fix is just as bad. :-[
Dysan motor to clutch belt deffo needs sorting, just a large piece of junk sat in the corner at the moment but a far better vac the Shark that was going to replace it. :-\
