Cambelt
Started by Terbs, 30 October 2023, 10:25:01
Terbs
Hi all....I know the cambelt fitting duration has been discussed on here many times, but I have a dilemma this time.......I have always been a staunch belt changer every four years on all of my Omega's. However this time, its been four years since Gixer changed the belt, but its only been driven a few hundred miles, if indeed that. It has been started regularly and run for a few minutes every week. I will probably get it changed, but does it need the full set. I thought someone said to me you only need the tensioner and a belt, is this correct.
Thanks....
Viral_Jim
Ultimately, this is really down to your comfort level.
I recently did the zafira at 103k and 14yrs old  :-X. The belt was shiny on the non-toothed side but there was no cracking. Clearly this will vary car to car but my point is, I wouldn't be as dogmatic as some about the 4yr interval.
Ultimately it's how much risk you're willing to take, and only you can decide that. :y
Considering the mileage covered, I would give it another couple of years especially if it's not going to be used much.
There's no point in only changing some of the parts.
This advice is worth exactly what you paid for it :y
I used to run mine to the full 80k but they were changed a damn sight sooner than the four year intervals. Any other Omega with limited/unknown history got a new belt as a matter of course.
I would suggest that going a bit longer won't hurt provided you religiously change the complete kit.
Reality is that the stated interval is deemed safe, but the vast majority will run for much longer without issue.  There is, of course, always the risk you will be one of the unlucky ones...
You pays your money and takes your choice ;)
When cambelt kits were cheap and readily available, it was a no brainer to do it, as it doesn't take that long. No idea about the avaiability of them now, or if available stock has been sat on damp shelves for decades etc...
Quote from: TheBoy on 30 October 2023, 13:26:09
This is a very good point.  You might end up fitting a belt that's older than the one on the car.  ::)
I've never been religious about cambelts. My V70 for example might well have the original belt, 19 years and 190,000 miles after it was fitted for all I know, as I have no paperwork or stamp in the book for a cambelt and I never got round to getting it done.  :-X
I know admitting that kind of behaviour on here is akin to heresy  ;D, but there must be millions of old cars happily going round with the original belt kit.  ???
Quote from: Sir Tigger KC on 30 October 2023, 14:25:06
Only in certain quarters. My Astra diesel got changed after 80K, and then I ran into c.120K before trading it. The Astra J we had before that got traded at around 90K, and it hadn't had a belt. I believe the original interval for omegas was 80K, until they started snapping well before that.
Diesel till I die
The reason they snapped early was because unscrupulous dealers wouldn't change anything other than the belt.
The 40k interval came about as a healthy dose of arse covering.
Quote from: Doctor Gollum on 30 October 2023, 15:49:51
weren't the original idler pulleys plastic?  :-\
Terbs
Thanks for the replies. I think I shall go with the consensus and hold back for a while. I am hoping to respray the roof and bonnet in December, then fit the new windscreen surround. Then early in the new year, see about getting the valve stem seals done, and obviously whilst it's stripped down, do the cam belt. James has given me a rough price for doing the aforementioned work. Car has only done 81, 000 miles, so I want to get it back on the road, mainly for local use.
On a slightly different topic, has anyone got their car on classic insurance, what are the limitations, and the cost.
Quote from: Andy B on 30 October 2023, 16:15:23
That won't have helped, but charging for the kit and only fitting the belt saves time and money ergo better margins for the dealer.
Keith ABS
Quote from: Terbs on 30 October 2023, 16:50:29
Depends on how old your car is Terbs but you could give Cherished insurance a look
You'll need to remove the screen to fit the windscreen surround, so be prudent to paint the roof whilst the screen is out... That way you can attend to any otherwise hidden issues and future proof the screen aperture/a pillars/roof edge ;)
Quote from: Terbs on 30 October 2023, 10:25:01
Thanks....
Got a similar situation with the silver Omega, only done a couple of thousand miles in over four years. Needs a Cambelt kit and an MOT on it :(
Makes sense to do the cambelt kit while it's here for stem seals. It has to come off anyway, so it won't cost you any more than the price of the kit. Plus it's pointless doing all that work to risk ruining it, by fitting an expired belt kit back on :y
