Radio on, no sound
Started by Migalot, 01 November 2023, 16:48:01
Quote from: dave the builder on 06 December 2023, 17:31:21
I've noticed the N/S/R door loom to be a problem (windows, speakers etc) on all 4 Carlton's I had plus other Vauxhalls
Have you ordered the door loom that goes inside the door   ???
surely it's the loom that cones out of the B pillar that's the issue (that plugs into the door ) by the hinge  :-\
that's if it's the same as the front setup
Astra has replacement repair loom sections for this issue , not sure about Omega B
The rear door plug is in the B post ;)
dave the builder
Quote from: Doctor Gollum on 06 December 2023, 17:41:17
Ah  :-[
Thanks Al
I never sit in the cheap seats in the back ,so didn't know  :P
Migalot
Thanks lads!
May have roped in an OOF member to help out!  :y ;)
Quote from: Migv6 le Frog Fan on 06 November 2023, 19:15:30
Whatever you buy make sure its DAB radio. It made the old radio we used to listen to redundant several years ago, but many people havent realised yet.  :y
My Jag has DAB. I tried it for one commute, decided it was utter sh1te and went back to FM.
Quote from: Kevin Wood on 07 December 2023, 07:43:39
I'm sure its fine for the BBC ensemble, and I'm sure the polishing brigade don't believe there are options beyond BBC R4. That even works on mine, despite 3 bloody great cracks across the rear screen.
Funny Mode isn't too bad on mine, despite the shagged screen, but in these parts its BBC or Heart.  Sadly, mine lacks the option of Aunty Mary :(
Needless to say, mines either on iPod or switched off ;D
Migv6 le Frog Fan
#65
Absolute classic rock. Planet rock. something or other classic 70,s.....etc. I find it pretty good.
There is even a Gaydio station for those of that persuasion. I think theres something for everyone on there.
Oh and theres GB News live.  :D
DAB is fine on my Astra, but the only time I have the radio on is while I'm waiting for the missus to run into the shops. Not very often  :)
Diesel till I die
Quote from: Migv6 le Frog Fan on 07 December 2023, 14:39:54
Good luck getting those in these parts.  Planet Rock does hog a (virtual) button on my DAB memory, but pointless until I get near the M40
That definitely hasn't reached these parts. Try again in about 30 years....
Migv6 le Frog Fan
Funnily enough I ventured well into Suffolk today and struggled to get a signal on most of the normal stations.
Im in a tiny village on the Essex / Suffolk border, so surprised there is a decent signal here.
Nothing wrong with the channels, it's the reception. Even Radio 4 doesn't make it more than a couple of miles into my commute, but FM is solid all the way.
cam.in.head
we had an old basic car radio sat on the shelf in our workshop  for years. never an issue.always worked fine .
lads decided it was time to go dab so brought in one.
takes ages to lock on to a station. sounds like a dalek most of the time !
same as digital tv reception. anywhere with less than perfect signal strength you get breaking up and blocking . old analogue always worked fine .
technogy advances are not always better and not always done for any other reason than getting one up on other manufacturers.
for example (and one of my major issues )with all this is.......
they make computers/ phones etc etc that can do virtually everything nowadays,advances in technology as far as you can imaging BUT why not actuall get the basics working right first. calls that dont connect,calls that break up,video calls etc that break up,freeze ,
Migalot
On the verge of giving up entirely.  >:( >:(
I took the door card off yesterday (without damaging anything!) with the intention of checking the loom today. After taking the card off, I turned on the ignition and the speakers came on. Great, I thought, must have jiggled something. Then I discovered that, with that speaker disconnected, all the rest work. In addition, SWMBO just told me that she moved the car yesterday a bit to allow builders to park outside the next door neighbour's house - before I had even taken the door card off - and the radio came on full blast for the first time in a week!
That means, logically, that the existing loom is OK and the fault must lie elsewhere.
It's wet and windy and I'm thoroughly pee'd off with it. Just going to clear up and put the door card back. I've officially got the hump with the bloody car. >:( >:(
Quote from: Migalot on 09 December 2023, 13:54:36
The existing loom has probably got a break somewhere which is intermittently touching together.
Diesel till I die
Migalot
Quote from: STEMO on 09 December 2023, 14:18:12
I have thought about that, but I can't see how that would affect all the speakers. However, today has shown that with one speaker out, the others still work. Furthermore, I have now discovered that my new Kenwood unit will display an error message if it detects a speaker fault. I mean it MAY be that, but frankly given the weather (working at the roadside), the shorter daylight hours, the amount of time it would take to remove the door card (again), remove the membrane, replace the loom and re-assemble – well, I'm not sure I can be ars*d.
I'm willing to pay to get someone to fix it, but finding a willing tradesperson ain't easy these days. The guy who installed the new unit is not responding to texts or phone calls.
Ho, hum.  :(
Depends if it's a break or a short. If a short, I'd hope the amp, even a cheap nasty chinky android unit, would detect and shut down the amp to protect itself.
