Radio on, no sound
Started by Migalot, 01 November 2023, 16:48:01
Migalot
As per subject.
Radio is on, all preselected stations there, but no sound from the speakers. Neither volume control on radio or on steering wheel have any effect. I thought it might be a fuse, but looking through the handbook, I can see no mention of one for the speaker/amp circuit.
Help please!
Migalot
Migalot
Update:
SWBO (abroad as of this morning) drove the car last night and she said it started making a crackling noise, so she turned it off.  :-\
Migalot
Update 2
Got in the car for a trip to Hatfield and the radio worked for about 30 seconds before going quiet again. After my appointment in Hatfield, it was pi**ing down with rain, so got a bit soaked going back to the car park. Anyway, go it and started...and on comes the radio as if nothing had happened. Stayed on all the way for the half-hour return trip.
Got me thinking. Was it water ingress which dried out on the trip up (which wasn't too wet)? If it was, why did it come on when the rain got heavy? Where could the water get in to stop all speakers?
It's a mystery to me. ???
cam.in.head
are we talking radio only no sound or other inputs too ?
if only radio dont they have an aerial amp or similar device up a windscreen pillar ? ( or somewhere ?)
Migalot
Quote from: cam.in.head on 02 November 2023, 17:54:15
I only have radio and CD. Haven't tried the latter, but will do when and of it stops raining!  ;)
Migalot
Radio worked fine on the way to the supermarket this afternoon. When I got back in...no radio. Decided to try a CD as VXL V6 suggested – no sound.
Started driving home and the radio suddenly came on for about a mile. Then the sound stopped again.
Beginning to think it must be a faulty speaker amp, which i presume is within the radio unit itself.
Anybody have any ideas/advice??
ronnyd
Have you checked the wiring behind the unit thoroughly?
Migalot
Quote from: ronnyd on 04 November 2023, 19:08:12
No. I tried removing the radio last year when I replaced the aircon control panel. Wouldn't budge (though i was using Halfords remove tool, which i later discovered was cr*p).
Can't see how the wiring could have moved/been damaged, unless there's been water ingress.
cam.in.head
ah well at least its not just radio related /areial.(which would have possibly been an easier fix ?)
sounds like the unit will have to be removed one way or the other .connections are worth checking obviously but cannot see that any bad connection on the back would allow the unit to still work but cut all 4 output channels.
unless anyone knows exactly where to look inside specifically it sounds like a bad internal solder joint or connection somewhere. i had a similar issue earlier this year with a different unit where everything was crisp and clear except the cassette output which was distorted. that took a lot of head scratching to sort. lots of joints were resoldered and various components swapped untill it was resolved.
one more silly question thou sorry probably not the fault but ....does your car have anything that splices into and cuts the audio for any reason such as a phone system or similar ?   wasnt some models fitted with a trafficmaster system ? how does that connect in ? ?
Migalot
Quote from: cam.in.head on 05 November 2023, 13:50:26
Yes, I'm in agreement with your diagnosis. Think it likely that it is a faulty joint inside the unit. I've ordered a new set of removal pins, specifically for the CDR 2005, so hopefully I'll be able to remove it. Frankly, I'm useless at soldering, so looking to get a secondhand unit or, conceivably, a new touch-screen unit. :-\
In answer to your second question, no i don't have anything that splices into the audio.
Migv6 le Frog Fan
The CDR2005 was a terrible unit. I would take the opportunity to replace it (and the old speakers) with something better / more modern.
Wont cost the earth and will make a big difference.
