Author Topic: cambelt 3.2 elite gates  (Read 22464 times)
john1959
  • birmingham
    • omega 3.2 elite black
« on: 25 November 2023, 21:31:02 »
had cambelts done 4 years 5 months ago done 20000 miles in that time gates say 5 year warranty, done 1000miles in the last year.when you think i should replace cambelt and tensioners and waterpump.cheers
    • 530D M Sport, 330i Coupe
Re: cambelt 3.2 elite gates
« Reply #1 on: 25 November 2023, 22:17:14 »
Whenever you feel comfortable with. As you probably know it's 4 years / 40K change intervals, anything deviating that is entirely your decision.
I have the same with one of mine that has only done a couple of thousand miles but as it's currently SORN it will be waiting until spring next year.
« Reply #2 on: 26 November 2023, 10:57:28 »
Realistically, you'd be unlucky for it to fail soon.  The GM lowered limit of 40k/4yrs was due to an unacceptable number of failures with the original 80k/8yrs.  Unacceptable probably means less than 5%.
When the kits were readily available at a sensible price, and can be done in an hour or 2 quite easily, it was a no brainer to stick to the GM recommendation.  Now the kits are scarce, and probably all old stock, that makes the decision more difficult, even more so if you have to pay a garage to fit it (and they probably can't fit it properly anyway)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 26 November 2023, 12:59:00 »
It's at half the mileage, and over the age limit. I would fit a timing belt kit in the next year or so.
The only reason to change the water pump is if it's leaking. The original suggestion to change it while you're in there was that reliably good quality replacements were readily available for so cheaply it wasn't worth not doing it. That's no longer the case, it isn't driven by the timing belt, and replacing it isn't that big a job.
Now that these engines are over twenty years old, I would put the extra time and a fiver into changing the crankshaft oil seal instead.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #4 on: 26 November 2023, 19:36:13 »
I would add that Serek at his Huntingdon SOS, garage, a OOF member, can be highly recommended to change our Omega cam belts, at a very realistic price.
Many of us use his services.  ;)
As for the cambelt kit itself, the correct Gates one is still readily available from Autodoc online. :)
« Last Edit: 26 November 2023, 19:39:48 by Lizzie Zoom »
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #5 on: 08 December 2023, 12:34:04 »
I've still got four of the AC Delco 3.0 kits which came up for sale at silly money.....think I bought eight in total, so that they could be robbed to make up kits for the 3.2's. ;)
« Reply #6 on: 08 December 2023, 17:13:20 »
But are they older than the ones on the car. I would imagine everything now is (very) old stock.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #7 on: 08 December 2023, 17:22:54 »
yes me too.
they were very cheap at the time. i got 6 .used 2 so ok for a fair few years yet at the mileage i do !
the offset pulley still works fine on a later engine although the shaft can be swapped over to a new bearing anyway.
Lizzie Zoom
  • South
« Reply #8 on: 10 December 2023, 11:38:34 »
No idea.  The Autodoc stock comes in from Poland/Germany and is for the Opel as well as Vauxhall  Omega, plus goodness what else. As long as they last the 4 years on the engine that is all I care about.
Surely  they didn't stop making them on the same day they stopped making the cars :D
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #9 on: 10 December 2023, 11:49:57 »
No, but the dealer is only obliged to supply spares for up to ten years after the final build date I believe. This still makes any ‘new’ belt very old.  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #10 on: 10 December 2023, 12:17:47 »
The belts are used for several other models ,so probably manufactured recently
the Gates I recently purchased  doesn't look "old"
obviously ,like tyres etc ,there is "new old stock" being sold too
  • Chatham, Kent
« Reply #11 on: 10 December 2023, 13:30:24 »
I wonder if the belt is only used on GM V6s? The Renault 24v V6 cam drive is very similar for instance. That would make recently manufactured parts more likely.
I've had some bad experiences with genuine NOS rubber parts like hoses, belts and seals and now my preference is for up to date  stock whenever possible. One forty year-old genuine Girling master cylinder(for a single circuit, non-servo Avenger, so a very limited use part :y ) bought from a specialist supplier was supplied with the advice "it comes with a pack of new seals, and we strongly recommend you use them".
« Reply #12 on: 14 December 2023, 12:01:19 »
The last GM.models fitted with it may have been as late as 2006.
Lizzie Zoom
  • South
« Reply #13 on: 14 December 2023, 17:12:08 »
Maybe. But Gates would have carried on making them as it was apparently not just an excluvie GM part.  I. Any case these belts are not made of tissue paper, but strong rubber.  I believed that it is the use of them on a very hot engine, with the massive tension over 4 years / 40k+ miles that destroys them eventually, not time spent in a spares department. ;)
« Reply #14 on: 14 December 2023, 18:07:09 »
Because no tyre has ever dried rotted. Ever :-X
Similarly, there's a reason why hot water bottles have expiry dates...
