engine ECU immobiliser.
Started by countrywoman, 29 January 2024, 19:54:26
countrywoman
So is it possible to deactivate the immobiliser in the engine ECU on a 96 3.0 V6 or is the only way by getting a key chip.
To get the chip you need a car pass. For the car pass you need the V5.
A Tech2 might be able to programme it out, but that's above my pay grade.
With the transponder apart a wiring diagram and an understanding of how it works, a solution might present itself.
If it's a MY 94/95, the immobiliser can be wired out.  If its MY96 onwards, it's a more advanced immobiliser setup that can't be wired out.  You may find a mapping company can map it out, but certainly standard diagnostic equipment can't.
Surely a paired ecu and transponder can be bought on eBay, etc. Or is that over simplistic?
Diesel till I die
Quote from: STEMO on 30 January 2024, 19:15:50
countrywoman
I will get a new transponder as that is the easy way, just a bit of faffing to get it sorted.
Quote from: countrywoman on 31 January 2024, 09:17:11
You'll need the V5 to get the car pass assuming you don't already have it.
