Author Topic: My Omega B2 2.2 16v from lemon to daily driver  (Read 144125 times)
0 Members and 5 Guests are viewing this topic.
RallyArde
  • Finland
    • Omega B2 2.2 16v
« on: 01 February 2024, 17:47:07 »
I decided to make separate topic from this one, propably making another from my V6 later on... ;)
I bought this five years ago:
Its 2001 model facelift/B2 Omega 2.2 litre petrol engine, with manual gearbox and 40% LSD. Also this has air conditioning ;D  Car had more than few issues... Cam cover was leaking, thorttle body was in oil (breather setup/one the hoses was blocked), brake pedal feel was horrible, handbrake wasnīt ok, exhaust manifold was leaking and two studs had been snapped, rear wheel arch needed to replaced , driver side sill needed to also replaced and couple original bits were missing/wrong.
First years I was mainly doing repairs to engine and brakes:
I drilled out snapped studs from the head and got manifold skimmed straight.
I changed cambelt etc.
I fixed oil breather system, by drilling hole in the throttle body from 1mm to 2mm and adding new hoses. Also new gasket to cam cover, yes o-rings as well and I found that missing Ecotec-plastic over cam cover.
I got calipers rebuilt with new pistons and seals, new brake hoses, discs and pads. I also changed new handbrake cable.
In summer 2022 I did the biggest fixes for exterior:
There is also a VLog about that on my channel:
https://www.youtube.com/watch?v=cA0rIWSTNKc
(unfortunately my english isnīt that good :-\  )
After I got car back on road and was almost ready for MoT, I get caught from drifting and lost my driving licence for almost two months  :'(
Eventually I got the car to MoT, and just drive it through winter, after all this is my daily driver.
Last but not least, I took rear beam out for overhaul, meaning new bushes and quick service to LSD ;D
Whole beam was rebuilt and installed back to car, after then I took it for suspension geometry allignment and boy it was great to drive again! :y
As you may have noticed Iīm going D-I-Y-principal and the only thing that wasnīt done by me was the allignment.
Propably I forgot mention something cause there are so many things Iīve done to this, but thatīs mostly all by this far.
Omega - when bad camber is actually a good camber
Re: My Omega B2 2.2 16v from lemon to daily driver
« Reply #1 on: 01 February 2024, 18:14:12 »
Some decent restoration/repair work there  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #2 on: 01 February 2024, 20:06:47 »
Nice work  :)
great photos  :)
your English is very good  :y
MikeV6
  • United Kingdom
    • 3.0 V6 Elite
« Reply #3 on: 02 February 2024, 13:40:55 »
Keep up the good work mate, I've subscribed to your channel  :y
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #4 on: 02 February 2024, 16:07:11 »
Thanks for your feedback guys! :)
I realized that there was no pictures or info from my wheels and tyres, but... originally had two sets of summer wheels for this, ones that are seen in earlier post came with car, and usually after summer they lookes likes this:
This is from 2021 ::)  I got cheap Triangle tyres, so I installed those and balanced the wheels.
Before this winter situation was almost the same:
At least I got used to aqua planing ;D
In november I started think which rims I would be putting on winter, so I came up solution to use former summer rims:
That leaves question for the summer right? And actually I found 100-edition 16" alloys, with few scarches:
I decided to refurbish them and give a new colour at the same ;)
I used 2k epoxy for primer.
And beige water base (Mercedes Benz, sand dune beige) and 2k clearcoat.
I got Nang Kang tyres some point but there was issues on threir strucktures/side walls, that reason I fitted Ovation tyres for the next summer:
There is the whole set waiting for me and summer 2024 8)
speedy_ns
  • Novi Sad Serbia
    • Omega B 2.5 DTI
« Reply #5 on: 03 February 2024, 08:26:28 »
Great job in saving one, they are becoming rare.  :y
I was always wandering how is to drive with those studded snow tyres.
Btw I believe that offset (ET) on those last wheels is incorrect for Omega, they look a bit sucked in, maybe you should consider some spacers.
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #6 on: 03 February 2024, 08:53:43 »
Thanks!
Those GT Radial studded tyres are actually quite good on snow and on ice, even they arenīt that expensive or as well known brand such as Michelin for example.
Here is little vid form November as the tyres were pretty fresh:
https://www.youtube.com/watch?v=6X5cUoAy8QI
On icy road car is still quite chuckable and predictable :)
Talking about offset; the black ones had ET39 but they are only 6,5" wide and are too much "inside", alloys for the summer had ET39 and they are 7" wide, propably using spacers (5mm?) would give better look.
« Reply #7 on: 03 February 2024, 09:17:58 »
Plenty of decent wheel options to not use spacers. 18x8.5j et 33 will give a decent stance with 245/40/18s
« Reply #8 on: 03 February 2024, 09:41:49 »
That's to say that 5 lug Vectra/Astra wheels may well fit, but the offsets are totally wrong, hence the visual discrepancy.
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #9 on: 03 February 2024, 11:25:19 »
Yeah, there are definately lots of options with better stance to Omega, I actually got a set 17x7,5" original Sport edition- wheels, but they are going to my V6 Omega ;) Eventhough the looks isnīt that good with those current 16" wheels, they are more suitable for everyday use in terms of tire costs (205/55R16 are pretty cheap aroud here) and also driving wise, enough comfort and not too grippy when having a little fun ;D  This gets driven a lot and I have change oils two times per year. Also there is less than 10 000km left of cambelt life, and propably next summer I have to change that as well.
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #10 on: 27 January 2025, 12:28:28 »
Little update after a year... ;D  I used this as a daily for the last spring, but I got few issues. The leftside front caliper was slightly binding (also pads were worn unevenly), cam cover was leaking oil AGAIN, some minor mifires during on accleration and floaty idle as well. During last summer I start work-on with along side with my other projects.
I ordered new geniune cam cover, there for I got 100% confindence that itīs straight and the crank case breaher channel inside isnīt clogged.
I also cleaned the thottle body and added new Elring gasket threre. This was also a good time for little "health check" therefore I took a quick look for old spark plugs and did a pressure test to the coolant system, everything seemed to be fine. Yes, I did replace sprak plugs.
New seals to calipers and new brake hoses just in case. Binding was gone 8)
https://www.youtube.com/watch?v=1mIPyFrFSyM
As it can been seen in the video as well ;)
After wash and interior clean up it was drivable again! Well in the summer I drove just the time that I got CCV replacement done for my 325i, but certailny I had fun :)
Before MoT one of the retaining pins of the rear brake shoes snapped ;( Luckily that happened while adjusting them, so I took old parts off and replaced pins and spring on both sides. Then in September this one passed MoT as well 8)
I did cambelt because the milage was full again. Nothing special on that and managed without locking tools.
Car was bery enjoyable to drive on damp tarmac during the last fall, chuckable and predictable, you feel how rear loses grip, catch it and control it, my V6 doesnīt currently have the same feeling despite suspension rebuilt so definately that needs a nre allignment, but I get into it later and another topic...
Winter came eventually and it was fun all the way, until left side rear calper started to bind about two weeks ago... ::)  Right now Iīm driving 325i and waiting better time to fix this, propably I will replace both calipers to rear or then I will overhaul them by adding new gaskets and pistons. Maybe some other minor fixes to the car also, weīll see :)
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #11 on: 26 July 2025, 07:44:26 »
Breaking the silence with my daily driver... ;)
https://youtu.be/fBh8cTYh_EM
Few more minor things left to be done anymore :)
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #12 on: 02 September 2025, 07:04:33 »
Some progress again...
https://youtu.be/yVxO_CJaNaE
Also a little hint from V6 Omegas current state ;D
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #13 on: 14 September 2025, 15:19:11 »
Because everybody may not been in the Youtube, Iīll post a "quick" recap what has happened to the car during last 3 moths ;)
I did replace the rear brake backing plates, and yes with long way, by pulling the hubs away and therefore also replaced the old wheel bearings as well. Should be ok for years on, new discs/drums, rebuilt calibers, retainers pins, levers, brake shoes and brake pads (which I replaced few weeks ago actually).
I gave car I quick wash at end of July and thought itīs ok for MoT and this is it... well it wasnīt ;D
There where corrosion almost.. everywhere ::)
I grinded rust spots away and used acid for neutralization.
I used anti rust putty as a filler before primers.
Prep work done. Pretty easy, cause I havent replaced any panels and there wasnīt large amount of filler used.
I applied two coats of epoxy primer and after short evaporation three layers of acryllic filler, so called wet-on-wet technique.
Then it was time for base and clear coat.
As I mentioned in the video I got one run, but I managed to wet sand it almost flat with a help of shim mask- tool.
Gave a colour to the front brake caliper brackets, after cleaning them first.
Added new discs and pads in the assembly phase.
I fixed wiring loom from the rear door and most imoprtantly washed the car inside and out 8)
Took the car back on the road Friday and drove a bit longer journey (over 420km) and car worked completely fine :y  Funny how slow but slidy this 144hp Omega can be in the rain ;D
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #14 on: 14 October 2025, 07:17:21 »
No video tihis time ;D but little update instead ;)
Yesterday car got an MoT fail due to handbrake that didnīt have enough strenght.
At very same day I did one last adjustment and got an MoT pass 8)
I change new oils (Valvoline 5w40 with GM specification) and filter, also replaced the air filter.
Looking forward for becoming winter :)
