Adblu top up
Started by raywilb, 14 February 2024, 23:01:30
raywilb
I have just started to get the warning that my adblu is low & I only have about 1500 kilometers before the engine wont start , on this car ( 2019 citroen c4 cactus 1.5 dti ,spacetourer ) the filling is situated next to the diesel . Nowhere in the user manual does it tell me how much of the ad blu that I need to put in . do i just fill until it takes no more?
YZ250
#1
I believe the Adblue tank capacity is 17 litres on Cactus.
Incidentally, I'm reading of more and more Adblue tank pump faults, heater faults and injector faults and they are bloody expensive to fix. This expensive to fix fault runs across all brands and is not particular to just the odd few car manufacturers. It's a piss poor (deliberate pun) set up, introduced in haste to appease emissions.
henryd
Quote from: raywilb on 14 February 2024, 23:01:30
Just brim it Ray,it won't do any harm
other rides
Our shows up fault codes every time the temperature dips below zero. Luckily, so far, the temperature has risen, and cleared the code, before the countdown mileage gets anywhere near zero.
Stick a 10 litre bottle in there, Ray, that should do you for around 10,000 miles.
Diesel till I die
Quote from: YZ250 on 14 February 2024, 23:42:53
That's why I bought a Euro4 R Class and, in part, why I replaced it with the S500... The diesel emissions components buy quite a lot of unleaded.
Quote from: STEMO on 15 February 2024, 07:22:31
Her car only has a 9l pigs piss tank.  Kinda annoying when its sold in 10l bottles!
Quote from: TheBoy on 15 February 2024, 15:30:50
All the Adblue I've bought in Costco has come in a gallon/5litre bottle  ;)
I saw a YouTube vid a while ago from an Irish mechanic who said to avoid buying pigs piss if it's stored outside, for example at a garage, as the UV light can form crystals in it and if they go in the tank it can cause expensive problems.
No idea if that's true or not, so don't shoot the messenger, but thought I'd share that little nugget of Irish wisdom with all you pigs piss consumers.  :y
Quote from: Sir Tigger KC on 15 February 2024, 16:54:10
You can buy stuff to stop it crystallising in the tank. I put some in when we got Mo's grandland because it was two years old with only 3000 miles under it, so had obviously stood around for a while.
Diesel till I die
......or you could buy a petrol car such as God himself drives. :)
Quote from: Field Marshal Dr. Opti on 15 February 2024, 18:29:22
I believe god gets very poor mpg.
Diesel till I die
Quote from: STEMO on 15 February 2024, 18:43:57
He made the world in 7 days and fed 5000 with a white sliced loaf and a couple of small haddock.
He can make a gallon of unleaded last for all eternity. :)
Quote from: Field Marshal Dr. Opti on 15 February 2024, 19:10:10
Well...I can't, so I'll get as close as I can with derv. Getting 52mpg around town in my Astra, a total necessity when you are a poor pensioner  :'(
Diesel till I die
Quote from: Andy B on 15 February 2024, 16:35:19
Ours sells the Redex in 10l, and not very cheaply either.
raywilb
I had about 6ltrs so that sorted it  :y
