Outside air temp sensor
Started by grifter, 16 February 2024, 10:26:52
grifter
3.2 Elite
So I was getting weird readings on my temp reading way below what it was, so replaced temp sensor behind bumper and doesn't seem to be any different, showing 0oC when it's about 9oC. Is this then the wiring at fault somewhere?
grifter
Panic over, it's now sitting at 9.5oC
If it's intermittent, it's often loom, usually either side of multi plug near horn
grifter
Quote from: TheBoy on 16 February 2024, 20:49:31
Readings were consistently lower than actual temp hence trying the sensor first.
