Signum ATF.
Started by Field Marshal Dr. Opti, 05 March 2024, 18:49:58
Quote from: TheBoy on 07 March 2024, 14:41:52
And what codes are in the engine and gearbox?
No codes or warning lights.....the car just got very hot after a while at 50 MPH, which is 5000 rpm in second gear.
Quote from: Field Marshal Dr. Opti on 07 March 2024, 16:57:18
If the gearbox was in limp, which sounds like it was if it just picked 1 gear, there will be codes in the gearbox.
Quote from: TheBoy on 07 March 2024, 17:17:50
I'll take another look. :y
Hooked up the Maxiscan 509, which was kindly given to me by an OOF member.
No codes  either stored or pending.
amba
Just get the oil changed ...it will thank you for it  :y
Quote from: amba on 08 March 2024, 13:33:00
I'll check out the cost. :y
Quote from: Field Marshal Dr. Opti on 08 March 2024, 12:30:01
Can that do gearbox, as its just a OBDII scanner...
Quote from: Field Marshal Dr. Opti on 08 March 2024, 14:19:54
Probably three figures, more than the car is worth.
Diesel till I die
Quote from: STEMO on 08 March 2024, 14:28:54
WBAC say she is worth £1160.....which is 4 figures. :D
Quote from: Field Marshal Dr. Opti on 08 March 2024, 14:35:48
Until they see it  ;D
Diesel till I die
Quote from: STEMO on 08 March 2024, 14:48:15
Future classic......£1160 is not nearly enough. :)
Quote from: TheBoy on 08 March 2024, 14:28:31
Absolutely no idea.
All I know is there are no new/old or pending codes. :)
amba
10ltrs of ATF should be about £70 depending on your choice and 1 hour at you local £60 per hour man and you get change for a pint and a pie out of £150 and the knowledge that you have done the gearbox a good turn.
Slightly more if you get the sump dropped and filter replaced .
A man of your wealth is just pocket change  ;D
Quote from: amba on 08 March 2024, 15:06:21
For my amusement I thought I'd contact my local Vauxhall dealer.
So....7 litres of ATF at £15 per litre plus the VAT comes to £126.
Add 2 hours of labour at £135 P/H plus VAT  comes to £324.
Total....£450. ;D ;D ;D
I would just leave it if it's working ok. Then the collective that is OOF can collectively piss ourselves when you get stuck in second miles from home and chant "Told you to get it done, tight arse"  ;D
Diesel till I die
