Wanted headlights
Started by mryummyone, 07 March 2024, 12:22:47
mryummyone
Looking for replacement headlights for my 1999 2.5 td cdx omega, new or used but must be in useable condition ( fail mot on headlights beam )
cam.in.head
two possabilities here assuming bulbs are correct types . lenses need polishing or adjusters broken ?
dave the builder
A bulb not seated correctly will often fail beam pattern , H7  :-\
cloudy lenses can be polished in situ
if self levelling Xeon then is the sensor on the wishbone functional. :-\
I would imagine broken adjusters, unless the lenses are very cloudy.
If it is the lenses, a standard 3M headlight polishing kit will do the job (or even sanding by hand, but then needs effort, LOL).
Broken adjusters are hugely common on Omegas. In the old days, somebody made aluminium ones which were superb, but no longer available.  I think some resin ones are available on ebay?  Fitting requires disassembly of headlight, which is fiddly, and needs popping in the oven.  Mrs TheBoy and I became quite a dab hand at doing them ;D
Quote from: dave the builder on 07 March 2024, 12:51:27
MFL CDX will be halogen, unless retro fitted (and I dont know any retrofits that bother with the levelling ;))
Personally I found the resin ones to be poor, I bought these and fitted them, no worse than the originals and should last the life of the car now, certainly been OK in one of mine for the last 3 years.
https://www.ebay.co.uk/itm/125416409940?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=gO1F9KL7RGi&sssrc=2047675&ssuid=0OC64k8KQ_m&widget_ver=artemis&media=COPY
Quote from: VXL V6 on 07 March 2024, 15:33:25
Yup, look better than resin ones, good find :y
woolley11
I've a pair of Xenon headlights complete which a 1999 CDX would probably have.
Is yours a PFL omega ?
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
