Author Topic: Irmscher fog light bulbs.  (Read 106983 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 20 April 2024, 17:24:16 »
A couple of my cars have a fog light out, and as the MOT's are due in a few weeks, thought a couple of new bulbs.. job done. But when I took one of the non working bulbs out ,it's an H1, and not knowing the history on the car I wouldn't know whether that is the correct bulb  fitment for the Irmscher bumper. I know that the H1 or the HB4 are for the standard Omega fog lights, but that H1 gets really hot in those small Irmscher fog light housings, and was wondering, if anyone knows what is the  correct bulb and required wattage is. TIA
Re: Irmscher fog light bulbs.
« Reply #1 on: 20 April 2024, 19:24:26 »
Think H1s are the wrong bulb for the Irmscher lamps :-\
I know I had to cut off the original plugs when I fitted mine but they were replaced with a different plug, but damned if I can recall the bulbs it came with.
It was bought new from Irmscher, so not previously interfered with, which second hand may have been.
The lamp casings were used on something else, Mundeo ST200 iirc... In which case H11 was quite probably what was fitted originally.
« Reply #2 on: 20 April 2024, 19:46:31 »
no idea of the bulbs but front fog lights aren't included in the MOT  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 20 April 2024, 20:01:13 »
Front fog lights are a testable item on cars first registered on or after 1 March 2018 also DRLs
also...
You need to test reversing lamps on vehicles first used from 1 September 2009.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 20 April 2024, 20:57:45 »
Thinking that Dr G's route is a strong option, it may be time to upgrade a bit. Just needed to know whether anyone had any problems in their past owner ship. Also thanks for the info on the MOT regs. :y
« Reply #5 on: 21 April 2024, 07:28:00 »
also...
Not applicable to a 20 odd yr old Omega then  ;)
« Reply #6 on: 21 April 2024, 07:42:24 »
Whilst they may not fail, isn't there a requirement that if equipment is fitted but not a compulsory item, ie rear wash wipe, it should work as expected otherwise be marked as an advisory item :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 21 April 2024, 11:15:09 »
"rear wash wipe" is not part of the MOT ,so may well not get tested at all ,
reversing lights on a pre 1 September 2009 are not a fail ,but may get an advisory ,similar to the spare tyre .
I guess it's down to the NT on the day ,he/she/them  ::) could miss such items whilst desperately trying to find something that is a fail/money making opportunity ,Kerching £$£$£  :D
Indicators on a BMW are tested , even though the BMW driver may never* use them
*Except when parked on double yellow lines , zigzags outside a school
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 21 April 2024, 11:29:32 »
One thing that is mandatory ,yet I doubt ever gets tested .....
"speedometer is working correctly and gives an accurate reading"
obviously speedos are NEVER tested on AUDIs, Golf GTIs (or golfs pretending to be GTI, with Ebay badges,) etc   :-\
    • Grandland 1.5 diesel
« Reply #9 on: 21 April 2024, 11:51:34 »
 ;D :y
Diesel till I die
« Reply #10 on: 21 April 2024, 20:32:51 »
A few years back ... maybe 10/13 ??? ..... I presented an Astra G for test with a none working speedo/odometer.
The car passed without comment! (eventually  ::) )
« Reply #11 on: 21 April 2024, 20:37:14 »
it's all down to a tester. My 4x4 ML goes for MOT to a place that can't do a rolling road brake test .... I think, by rights, he should do a deceleration test on a road test .... but has never done so. He never tests my 13 pin trailer socket either! He's never tested my reverse lights!
I still take my cars to him for test though!  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 21 April 2024, 21:13:45 »
The NT (Tester) should have noted the NON readable  odometer on the certificate
what did he /she/them ::) put as the milage ? did he/she/them look at the ECM data  ??? just guess  ??? or ask YOU ,the vehicle presenter to guess  :D
13 pin sockets are testable when fitted ,7 pin are not (there is no standard wiring configuration for 7 pin)
A decelerometer is 'probably' used when driving the vehicle into the test bay  :-X
Reverse lights would have activated getting the vehicle off the ramp , or are you still at the test station waiting for your car  :D
I pay full fee for MOTs ,the tester (ex police) is very strict
I see that as a good thing
though I do prep my cars BEFORE presenting them for MOT ,so rarely have retests (which costs time and money)
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #13 on: 21 April 2024, 22:21:19 »
High level / 3rd brake lights are apparantly not a testable item, even if fitted. The one on my wife's 2017 Honda CRV doesn't work, and Honda have MOT'd it for the last two years, and whilst pointing it out on the 'items that require repair / replacement', they stated its not an MOT fail. Genuine Honda lamps are approx. £140 **, so if they could squeeze more money out of her, then I'm sure they would have done.
**Chinese copy units are available for less than £20, but supposedly they are a 'poor' fit...surprisingly ::) ::)
« Reply #14 on: 21 April 2024, 23:42:44 »
He put down what the odometer said .... which was the same as the previous year  ;)
