Author Topic: Water in Astra J Fastback Boot, year 2010  (Read 1030 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 03 May 2024, 12:11:49 »
Realized it Last Summer but thouht that boot had been open. No, it is not that. Very much water. Where can it come from. The spare weel in bottom is swimming in water. Only thing I see is the rear wiper shaft going through rear window is a bit loose, please help.
Re: Water in Astra J Fastback Boot, year 2010
« Reply #1 on: 03 May 2024, 12:47:54 »
Check the seal where the wiring loom connects to the rear lights, pop the lights out for a better look
« Reply #2 on: 03 May 2024, 13:59:36 »
That won't fill up the spare wheel well on an estate as it will drain into the rear quarters first... :-\ Unless sooo much water is getting in that it's running along the rear panel seam, but even then it would have to overflow the lip where the latch is. That said, it could be running down the loom between the rear lights, but it would be coming from higher up...
Any evidence of rust at the bottom rear corners of the rear quarter glass? If yes, then expect a hole behind the black trim. Easy enough to access: remove the inner trim from the C and D pillars and undo the twenty thousand 10mm nuts. Window then comes out and you can access the screws that hold the trim in place. Should be possible to effect a decent repair without it showing past the trim... But whatever you do, don't fill the trim with sealant.
The body vents are into the wheel well, but unless the car was reversed into a pond and left there it should drain out through them. Incidentally those vents are designed to open towards the low pressure at the back of the car as it moves forwards and hang closed when stopped. Ignore all of that, it's an Astra, not the Omega ::)
    • Astra 1.6 diesel
« Reply #3 on: 03 May 2024, 15:27:18 »
Estate? I thought he was describing a GTC, or hatch.
« Last Edit: 03 May 2024, 15:29:08 by STEMO »
Diesel till I die
polilara
  • Finland
« Reply #4 on: 03 May 2024, 15:41:08 »
Ye@s, not Estate but Fastback meaning "Short Roof".
    • Astra 1.6 diesel
« Reply #5 on: 03 May 2024, 16:01:19 »
So....back to Marks suggestion about the light seal then.
Diesel till I die
polilara
  • Finland
« Reply #6 on: 03 May 2024, 16:10:37 »
Yes, now in Mobile home, let's see on Monday.
    • 2 Fords
« Reply #7 on: 03 May 2024, 18:46:14 »
The spare wheel well used to become a pond in my Mondeo hatch as well, and I found that behind the rear bumper there are two vents on each rear quarter where the bumper wraps around and the seals had failed on both, letting water into the boot.
Removed the bumper, refitted and resealed the vents with silicone, and that sorted the problem.  :y
You may or may not have a similar issue, but worth finding and checking the vents are watertight.  :)
johnnydog
  • Lancashire
    • 2.6 & 3.2 sal, 3.2 est
« Reply #8 on: 05 May 2024, 15:43:51 »
Your point is not really correct Gollum. Whether an estate or hatch back or saloon, water will travel around the rear tailgate / around the boot aperture, and if there any areas with poor seals etc en route will be a source of water ingress.
My grandaughters 06 Ford Fiesta got a puddle in the spare wheel well everytime it rained. I traced that to a seal behind the rear light cluster where a plastic bracket housed the wiring loom and had a sponge like seal (? ::?) against the body. Removed the seal, and replaced the bracket with a bead of permanently flexible DumDum, and its been dry as a bone ever since.
2002 3.2 Elite saloon, 2003 3.2 Elite estate, 2003 2.6 Elite saloon
« Reply #9 on: 06 May 2024, 00:32:40 »
My post was specifically in relation to the Omega Estate and was from experience of being perhaps one of two people on this forum who has actually replaced a rear quarter panel.
I acknowledged that I was wrong in that the vehicle in question here is in fact an Astra, but I left my post otherwise unedited as.iy.is very much relevant to the Omega Estate and may therefore be of use to someone down the road.
polilara
  • Finland
« Reply #10 on: 07 May 2024, 19:59:52 »
Thanks for all tips, now back at home and checked rear lights grommets acc. to Marks suggestion. Both sides ok in wings, have to check same thing in tailgate cover side tomorrow. Seem to be a common problem in Astra J, Internet is full of text about this. The "Rear Box" and rear Bumper might have a role here. When rear light were off I saw a hole in bottom there going somewhere down, perhaps the water goes somewhere from there but not out, it is a bit strange construction. Have to study it with my wife, so that I am inside and she spray water with garden hose etc.
Page created in 0.038 seconds with 21 queries.
