Author Topic: Cant resync key.  (Read 60848 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Cant resync key.
« Reply #15 on: 29 May 2024, 12:22:48 »
 :o ;D
Migv6 le Frog Fan
« Reply #16 on: 01 June 2024, 14:05:40 »
Had a look at the internals under the microscope at work last night. Couldnt see anything obviously amiss.
Just been out to try the resync again but no luck.
I have discovered though, that it will unlock the boot ok, but does nothing with the doors.  ???
« Reply #17 on: 01 June 2024, 18:08:45 »
So its sync'd then
Replace the switches
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18 on: 01 June 2024, 18:10:42 »
so it will be the open/close buttons then
If the rubber case splits then "finger cheese " can get in the micro switches/buttons
washing with isopropyl alcohol (fob battery removed) can sometimes revive the switches
Migv6 le Frog Fan
« Reply #19 on: 01 June 2024, 18:13:33 »
Had an Isopropyl wash last night. The case is in pretty good condition.
Anyone know a good source of switches please ?
Can hopefully get them changed at work, although my go to man has recently retired.
Both switches packed in at the same time though ?  ???
« Last Edit: 01 June 2024, 18:15:50 by Migv6 le Frog Fan »
« Reply #20 on: 01 June 2024, 18:26:42 »
RS, CPC-Farnell etc.
« Reply #21 on: 01 June 2024, 18:27:25 »
Or in the good old days, the OOF Shop ;D
Migv6 le Frog Fan
« Reply #22 on: 01 June 2024, 22:57:43 »
Yeah but - what to look for on the sites. Does it actually say 2 Vauxhall Omega facelift, key fob switches >
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #24 on: 06 June 2024, 09:51:43 »
Or PM me you address and I'll post some
Migv6 le Frog Fan
« Reply #25 on: 06 June 2024, 13:48:37 »
Had a set arrive in the post 10 minutes ago, but thanks.  :y
Migv6 le Frog Fan
« Reply #26 on: 14 June 2024, 16:14:58 »
New switches fitted and key working as it should again. Happy days.  :)
Just need to find the problem with drivers side heating now. Theres always something.  ::)
